Badger5Chris Nott
Results 1 to 16 of 16
Like Tree7Likes
  • 1 Post By Macdoon
  • 1 Post By B7_FUR
  • 1 Post By NOZ
  • 2 Post By g00se
  • 1 Post By Steve77
  • 1 Post By Furkz
Thread: ALL LIGHTS - Front Facing
    Furkz's Avatar
    Apr 2013
    298
    hi, i have S-Line A4 B7 Avant 2005 and thinking of changing all the lightbulbs at the front to ice white. The Phillips Diamond white really take my fancy with some led sidelights and ice white fogs... what i wanted to know is it only the side light bulbs that throw up an error code on the dash or do i need to check all the bulbs before i buy.
    just for the record im changing
    sidelights
    fogs
    main beam and dipped
    also is it true that on a S-Line you dont need to remove the bumper to change the bulbs?
    Thanks In Advance
    Phantom Audi A4 B7 S-Line Avant
    Macdoon's Avatar
    Essex
    1,575
    T8ups (Trups) a sponsor on here can supply you with everything you need fella, contact him he will see you right.
    The bumber does not need to be removed to change the bulbs.
    Mac
    Furkz likes this.
    A4 B8 (09) 2.0 TFSI (211)
    Gloss black RS4 style mesh grille,fog grilles,splitter trim,A8 boot rings,rear diffuser & door blades.
    Ice White fogs, Tints, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior,satin black exhaust tips, black calipers/red Audi rings.
    Furkz's Avatar
    Apr 2013
    298
    I just contacted him thanks. Is there a guide on how to change the bulbs on a S-Line
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    346
    Headlights are fairly easy just unclip, sidelights need a good tug, don't twist! Fogs and sline are easy I believe just remove surround and you can access them that way.
    Furkz likes this.
    A4 Avant B7
    LED Rear Lights - Mesh Grill - SLC Splittler - Ice White Fogs - Tints - Devil Eyes - Ambient lighting - LED interior
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    192
    fog lights here AUDI A4 FOGLIGHTS (REPLACE AND UPGRADE) with PIAA H11 BULBS - YouTube
    follow steps 1.2.3.4 to remove bulb a tight squeeze with your hand but easy enough
    Headlight Bulb Change on A4 2006 (B7)
    Furkz likes this.
    Furkz's Avatar
    Apr 2013
    298
    Thanks guys I should be ok now
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    I've just done my sides and headlights (main and dipped). Makes a big difference
    Sidelights were a bit of a pain to do - bit unnerving having to tug on the wires like that, but got there in the end.
    I didnt bother with the fog lights, cos frankly, within the last 10 years, I could probably count on both hands the number of times i've had to use front fogs..... and in weather where you do need fog lights, I dont think anyones really looking at how nice and white your bulbs are.
    Guess its nice to have it all matching, but in lets be honest, your front fogs are going to be predominantly un-noticed, unless you like to use them incorrectly.
    Just my tuppence though
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by ESD1711 View Post
    one of my pet hates that ^^^^^ bl00dy dangerous too
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    Furkz's Avatar
    Apr 2013
    298
    yeah im one of those guys that drive around on clear days with side and fog lights on and at night main beam and fogs. just because i like to be seen.... (sarcasm on a friday morning )
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by SL4VE View Post
    just because i like to be scene....
    goose
    ESD1711 and Furkz like this.
    Current:
    Past:
    Jun 2010
    63
    T8ups sorted out all my bulbs. And they look awesome.
    Check this post I put up with the Main & High beams changed:
    Headlight Upgrade
    I've since done the Fogs too and it looks awesome but so bright any pictures I try and take come out dazzled. haha
    Furkz likes this.
    Furkz's Avatar
    Apr 2013
    298
    Just done them all what a mission. Fog light screws were rounded off. Wire came off sidelights. Starting raining hard. Am all cold and wet and feel abused. I guess I had to change these sooner or later. Thanks to trups for the bulbs
    t8ups likes this.
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    248
    How much did the whole lot set you back if you don't mind me asking, I want to do mine
    Furkz's Avatar
    Apr 2013
    298
    29.10
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    That was what I feared when I was doing the sidelights. How did you manage to get the holder out if the wire came off?!
    Bit of a bonkers design if you ask me!
    Furkz's Avatar
    Apr 2013
    298
    was only one wire, tbh i pushed it back in and the lights worked fine for a bit but sidelights are now not working and one beam bulb is blown. currently under investigation - so no comment whats at fault here
  1. exterior lights, front and rear
    By woddle1000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th October 2011, 18:40
  2. Fog Light (front) retrofit
    By social_mogul in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 16:11
  3. Light front end
    By jibbajabba in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2007, 16:46
  4. Orange signaling light (Front Corners)
    By Hryco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2004, 21:14
