The return springs are strong so if you're pulling it out probably best to get someone to operate the washers and grip the shaft - this sounds so wrong - to stop it going back in. The plastic cap is just held on with some small plastic clips and comes off quite easily, it'll probably just come off in your hand or break if you pull that.
If you are not fussed about having them I would just push it back in and pull the earth wire from the pump, it's inside the nearside wheel arch cover in the engine bay, reservoir has 2 pumps on it, I can't remember which one is the screen and which one is the lights, but that would disable it. Don't know what kind of lights you've got, if they are manually adjustable that will probably be OK, if they are xenons you might be taking a chance at mot time, although mine just passed and I'd forgotten to switch the washers back on.
