AH FabricationsSky Insurance
Results 1 to 17 of 17
Thread: Faulty PCV ????
    Sep 2010
    26
    Angry Faulty PCV ????
    Hi all,
    I think i have may have a faulty PCV valve on my 20tfsi A4. Oil around the rocker cover and coil packs, small amount of suction on oil filler cap, when the oil filler cap is removed the engine stutters and then stalls. Tickover is a little lumpy but always has been
    I also have increasingly high oil consumption - now around 1ltr to 500 - 1000 miles depending on use (better on M ways).
    Other than this the car runs fine.
    Any help and advice appreciated.
    It's a Sline special edition (22bhp) Avant Quattro 2007 model.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    sounds like it could be
    just change it there not to much £££
    and easy to change
    Sep 2010
    26
    Fixed. Version C out Version N in. Car feels better, smoother and let's hope the oil consumption improves. The old PCV was gunked up and didn't have the rattle of the new one.
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    247
    I replaced ours not long ago made a huge difference, oil consumption is better but still feels wrong topping it up all the time. Some owners replace the breather pipe when changing the PCV I didnt on mine but wondered what people's thoughts were on this
    Sep 2010
    26
    Quote Originally Posted by Chris-Vspec View Post
    By the breather pipe do you mean the rippled alloy pipe that goes from the rocker cover to the turbo air inlet?
    Molnboman's Avatar
    Quote Originally Posted by snoopy View Post
    is that the oil catch can upgrade that I read about http://www.stertman.com/ui/templates...7_20t_catchcan and aren't Forge developing one too. I find it puzzling how some owner's engines don't touch any oil while others guzzle the stuff. Really weird imho!
    A
    Sep 2010
    26
    Quote Originally Posted by Molnboman View Post
    A
    Cheers for that. If the new Audi version doesn't make any difference on oil use I'll consider one of these. Looks complex though!?
    So far the car is running better, low rev pull is way better with a much smoother tick over. It's quieter too even on the motorway, the exhaust used to be quite boomie but that seems to have quieted down a bit
    UPDATE. OIL LIGHT ON AGAIN, thats 1 LTR IN 492 miles so the new pcv may have improved the running of the car but its done sweet FA to help the oil use.
    Anyone got any advice?
    Mar 2013
    Verwood, Dorset
    247
    That oil consumption seems a little high to me, have you spoken to Audi about it? Mine uses some oil but no where near that much
    Sep 2010
    26
    Almost afraid to contact Audi. I might call my local dealership and see what the service manager says. He will probably say bring the car in and we'll look at it. Cha Ching.
    Mar 2013
    Verwood, Dorset
    247
    I'm not sure where you are but I have a good friend who works for Audi in the service and parts dept Salisbury, if you are struggling drop me a pm with your car info and I will ask him for you, at least that way you will get an honest reply
    Jul 2011
    12
    Hi I was having the same issue as you a while back I have a dtm which is basically the same engine you have. Turned out it was my turbo that was the cause of the oil consumption seemed to boost just fine and plenty of power but the mechanic took off the intercooler hose and it had quite a lot of oil in there also on further inspection there was a nice bit of play in the shaft. If it is the turbo it might not break the bank though cant remember the exact figure but they are offered on an exchange so that should soften the blow a bit. Let me know how you get on
    Molnboman's Avatar
    Is the symptom for a f@cked PCV, loss of oil? My PCV was shot to bits but there was no loss of oil as a result of the state it was in.
    A
    Sep 2010
    26
    A
    it can according to others cause undue pressure in the crankcase forcing oil past the piston rings, that's what I have read on other posts/forums.
    Sep 2010
    26
    Just a quick update, the car is having some tests done a week on Tuesday. The garage are checking the turbo and pumping pressurised air in to the cylinders to see what happens. They also mentioned a smoke machine that highlights blockages, leaks and breathing problems.
    Molnboman's Avatar
    Good luck Matey....sounds like a compression test to me!smoke machines?......Jaysus they will be slitting a goat's throat at midnight dressed in black at this rate! Hope you get to the bottom of it anyway and keep us posted.
    BR
    Allan
    Sep 2010
    26
    Car back from the garage. Turbo is ok. Smoke test revealed a breathing problem so they have fixed that and told be to see if it helps. More later...
    Biddyy's Avatar
    Mar 2013
    40
    It's much later! Any news - fearing I have the same issue! gulp!
    2006 A4 DTM, Silver, Front and rear OEM Parking sensors, OEM RS4 Xenons, OEM RNS-E plus, 6 Stack CD Changer, APR Carbonio CAI, Rev D DV, Autotech HPFP + OEM Follower, Revo Stage 1, New thermostat, R8 RED Coil packs, so far!
    To Do: Coilovers, Sport Cat RAI/034, Milltek Cat Back, Revo Stage 2+, & finally take a break?!
    "quattro - try it, you won't look back!" :D
  1. Symptoms of a faulty PCV valve?
    By jk_s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2013, 17:08
  2. S3 FAULTY PCV--- Advice
    By gynads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2010, 09:04
  3. Faulty Rear Speakers/Sub
    By Masterm8fo in forum In-Car Entertainment
    Last Post: 16th September 2004, 08:51
  4. Faulty Viper DV????
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 01:02
  5. Faulty glovebox/boot lights
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2004, 17:20
