Badger5Volks Autos
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Low oil indicator
    Hi guys I seem to have a fault with my oil indicator I check my oil in the morning with a cold engine and it reads full on the dip stick but after the engine warms but not all the time the warning indicator flashes up on the dis and stays but if I open the bonnet and check the dip stick it goes dose this look like a fault with the sensor or the beginning of a more serious problem cheers for help
    Mar 2011
    North Wales
    210
    Most likely a fault with the sensor. Mine is the same, planning on replacing it when I change the oil in a couple of months.
    Opening the bonnet resets the warning light.
  1. do all a3's indicate low oil?
    By harvz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2013, 22:05
  2. Washer Fluid Reservoir Low-Level Indicator
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2007, 18:54
  3. Resetting The low oil warning light.
    By Biggles in forum General Technical / How To
    Last Post: 19th January 2007, 09:08
  4. A4 B7 2.0TDi Low Oil Level Warning Light
    By stedes in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd November 2005, 18:31
  5. Low oil?
    By synthdood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2005, 16:19
