JMB RetrofitsSky Insurance
Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By T3nnant
  • 1 Post By ESD1711
Thread: Brushed (DIY) chrome
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    Since the "milky" chrome alu seems to be a pretty common problem, with no fixes apart from painting...
    Has anyone tried sanding it down to give it a brushed alu look?
    If so id love to hear how it went and turned out.
    Having serious thoughts of trying it.
    CHEZ likes this.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,756
    plasti dip mate?
    do not forget to vote!
    AUDI A4 B6 or B7 which is the best looking?
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    Quote Originally Posted by CHEZ View Post
    plasti dip mate?
    Did this with my grille mate and turned out ok, until started to peel.
    just bought 4 cans of paint so im in the middle on what to do
    Joe Clooney's Avatar
    Sep 2012
    co.laois ireland
    54
    just peel it off mate and do it again, I had a couple of bits on mine peel down at the very bottom, just repainted the bottom section and it blended in perfect with the old plastidip.
    2007 Dolphin Grey B7 Avant 1.9 115 S Line
    Apr 2010
    346
    i have a brushed chrome /alu effect on my dash in lays that looks pretty good i would like to see what it would look like on the exterior chrome
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Quote Originally Posted by T3nnant View Post
    It's plastic mate. Getting it wrapped is what most seem to do. Want to get mine done soon. You could probably paint it, I've had that suggested to me.
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    322
    Wrapping is definitely the way to go!
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE VW Touareg wheels with 25mm spacer/adapters all round, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
    Sep 2012
    co.laois ireland
    54
    Do you have to take it off to get it wrapped or can it be done in position?
    Molnboman's Avatar
    Just for the record, I think he rails are polished alloy and not chrome, hence people getting the milk effect when using a metal polish on them. Easy route would be to plastidip, tricky and better route is wrapping them. You will have to do both while the rails are attached. To remove the rails you we need to take the cabin roof lining out, which would be time consuming and a basta@rd one would think.
    Good Luck,
    BR
    A
    Feb 2013
    Wiltshire
    346
    Quote Originally Posted by Molnboman View Post
    Good Luck,
    BR
    A
    I presumed he was meaning the chrome strips around the windows. These cannot be removed (not without destroying them) and replacements are ridiculous in cost! The best way to get them sorted is to get them professionally painted. After that its wrap then plasti-dip.
    The problem with plasti-dip is the plastic chrome is a bugger for it to stick to properly. I have done my boot strip in plasti-dip, and while its not bad, its not great. The adhesion is not fantastic. It would be better with a light sanding with something like 1000 grit to give it a little purchase, and use an undercoat. But at that stage, might as well use proper paint and make it permanent. And therefore worth getting it professionally done.
    Vinyl wrapping them is defiantly not a diy job. Well it is, as is anything really, but its a very tricky job. There are lots of slight angles, and small amounts that need covered. Again, in my opinion, worth getting it done professionally.
    If you want to give it all a go, i would advise plast-dip to start with. Its very quick, and while not permanent and can peel off, its pretty easy to do. And its cheap. While its not perfect, and it wont look smooth (plasti-dip comes in a more rubbery texture), it will give you a good indicator for you to see if you like it black or not. If so, then worth getting it done professionally.
    Jan 2013
    Moray
    228
    If you're going to light sand it, you might as well paint it properly! Plastidip is utterly terrible to put on exteriors. Vinyl wrap or painting them are the only 2 long term solutions.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Apr 2013
    140
    Vinyl wrapping is piss mate. I did my mates Mini cooper S chrome surrounds. It is tricky sometimes but ive been doing it a while and its all about practice and for the money its not going to break the bank if you do mess up.
    If you want something thats really easy to apply, try the 3M vinyls with the controltac adhesive, it doesn't stick until you apply pressure so its nice and easy to position it.
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    thanks for all the suggestions.
    I have done a bit of wrapping, and i did have a quick go on the surrounds. Alot harder than i thought!
    i started at the back with the smallest window, there are soo many angles you need to cut and is a real pain in the arse.
    + i did have chrome showing through which was a major contrast to the black.
    Iv done plasti dip on grille before but as said above its not the best at sticking to a smooth finish without undercoats or something.
    Im starting to edge towards proper bodyshop painting, but that will want me to get the rest of the car sorted too.
    Although i have seen a couple of places near to where i work which are "vinal signs and graphics for vehicles" Im rather tempted to pop in and see if they could professionaly wrap them, then i can get some sort of warranty on them lasting.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    Having just gotten mine wrapped, I'd defo recommend that route - very pleased with the outcome
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    829
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by ESD1711 View Post
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Pics in here buddy
    Bye bye chrome
    jdp1962 likes this.
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    looks great!
    not sure i could pull that off though, im not the best with the stuff.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    829
    Pics in here buddy
    Bye bye chrome
    Thanks!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,697
    looks great!
    Me neither. That's a lovely job, but you can bet your pension it wouldn't look like that if I did it.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    I wouldnt have tackled it myself either to be honest - but its maybe worth getting a quote from someone to do it?
    I'd recommend my guy, but he's up here in Scotland.
    The window surrounds actually looked like a lot easier job than the grille surround... but its easy for me to say that when I was jsut watching on haha!
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Did you use the rattle cans of PD?
    I've noticed the spray gun version of PD sticks better than the rattle can and lasts longer.
    Also the cleaning of the surface helps a lot.
    I did my mates Saab grill which is chrome and he's not had any issues with it for last 6 months.
    I'm more than willing to do you grill for you.
    I got black, Gunmetal or fluorescent red in stock.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    Bit of a distance sadly haha, im guna get a quote though I think, simplest option.
    Quote Originally Posted by ScottB5 View Post
    I used rattle can ye I can imagine the proper mixed stuff will be better though, tends to be. To be honest if I was going to have it redone, id probs go for wrapping as seems to last longer.
    Feb 2013
    Wiltshire
    346
    I've been wanting to do my front grill for ages. Thinking of just pulling off my bumper and spraying the grill. Need to figure out how to remove it from the bumper though! :D
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    Quote Originally Posted by ricostuart View Post
    I think its just held in with little plastic push through clips.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Shame its not a 10min trip down the motorway lol.
    Wrap can last longer than dip dipping on its application.
    My roof has lasted very well I think, for all the miles, weather and jet washes it's been through. It might help that its a larger area than a grill.
    Ricostuart, leave the grill on and spray it in situ.
  1. Chrome or brushed alluminium wing mirrors???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2008, 22:43
  2. hagus brushed chrome mirror covers
    By Scottie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2007, 23:43
  3. Brushed Aluminium/Stainless/Chrome mirrors?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2006, 08:39
  4. brushed chrome mirror covers
    By imported_Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 20:30
  5. Chrome mirrors for the S3
    By joesa in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2003, 11:21
