Chris NottBadger5
Like Tree1Likes
  • 1 Post By ricostuart
Thread: Thinking of starting my project....
    Feb 2013
    Wiltshire
    346
    Ok, so I have my b7 s4 and decided to take off the rear bumper and do some wire testing on the parking sensor loom. All tested well, and so i took off the front bumper and tested each individual rear parking sensor on the front loom. All except one was dead! So bought 4 more and will have some new ones shortly.
    While doing all that, I noticed that the whole car was completly covered in a thick dust. The car used to be parked at a farm, so it must have sat for quite a bit and was covered. All vents has a thick coating, and under all the arches was a thick coating of mud (took about 2 mins scraping with a screwdriver before hitting metal!).
    So after all that, i think its time to start work on the car. I plan to gut the interior all the way to the chasis and steam clean everything inside. Will then remove all body panels and clean (and possibly repaint) everything I can. Will get the car up on stands and remove all the suspension components and replace all parts that need replacing, clean what doesnt and paint what can be seen. essentially I want to remove everything, replace and repair whats needing done, and anything thats in good nick wiill repack with grease if i can and make sure its all 100%. Eventually want to pull out the engine/transmission (i have access to a high lift) and do a rebuild.
    So after this little story, what do you guys think I should do in what order? The car runs very well at the moment (a few niggles but then it is a 2005 car!), so there is nothing essential at the moment. I'm essentially doing a semi-restoration project! I will do mods at the same time (especially when engine is out).
    CHEZ likes this.
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    Quote Originally Posted by ricostuart View Post
    Crikey, that's a huge project you got yourself there! I would give the car a very good clean first to see the condition of the bodyshell. If it needs lots of metal/welding/filler/paint consider selling or parting it out, likewise with regards engine and transmission make sure all is well before going any further. It's unlikely you'll ever get back your investment on future resale on these big bill items. The trim, suspension and brakes are cheap in comparison. If all looks worth it, go for it and keep us updated -lots of pics always appreciated!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Feb 2013
    Wiltshire
    346
    Going to be a big but rewarding project! the body is in good condition at the moment with only very slight rust on a edge. two second fix. there will be loads of photos and videos too! :-)
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,756
    some good ideas dude!
    do not forget to vote! here,...AUDI A4 B6 or B7 which is the best looking?
  1. advise before starting a project
    By camerontarver in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2013, 08:47
  2. Finally starting the project on the A4 Quattro Sport
    By matt_simo1 in forum The Project Room
    Last Post: 8th October 2012, 13:57
  3. Project Audi A3 (start date 27th april 10 )
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2012, 18:21
  4. help car wont start think fuel prob
    By jim s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2009, 16:50
  5. Started painting my door switch surrounds. What do you think?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2005, 22:58
