Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By dannyboy75
Thread: points to look for on S LINE TFSI QUATTRO 2.0t
    May 2013
    41
    new to the site and in the next month or so looking for one of the above ive only got about 6k so looking at high mileage one 55 ish plate, whats main thing I need to look out for on them, ive read already to make sure its got full service history to help stop the oil pump problem and weak dv and notchy gearbox when cold means the oil needs changing
    is there anything suspension wise to look out for on high mileage ones ?
    also ive noticed some come with se bumpers so il make sure to get one with the proper s line bumper thanks tom
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    they only come with se bumper on the cab
    make sure belts water pump has been done
    full service history wont stop the pick up pipe oil pump problem
    if thats gona go it will go
    even high miles your gona be pushing it for 6k on a B7
    shady-ninja's Avatar
    857
    check for leaky differentials on Quattro.
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Welcome to the site!
    Check my build thread for some info.
    6k is little so take care looking.
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    May 2013
    41
    Cheers for the reply people
    i know 6k is pushing it but its all I have to play with haha if I can get more I will there's a few on the bay of evil for 5.5k just need to go see them
    Will be checking there is nothing leaking
    i will check it out thanks for the link as I will mod my eventually
    Mar 2013
    Near Oxford
    405
    it's crazy how much more the B7 is over a B6, you could get a mint B6 S line Quattro for that, and only a year older. Better looking, better engine......
    Rod cast, now waiting for bites.
    Jul 2012
    192
    check if the cam belt / water pump has been replaced.
    think the cam belt needs to be changed after 60k or 5 years which ever comes first.
    Generally good reliable engines
    May 2013
    41
    I prefer the look of the b7 think its worth the extra few quid for it
    glad there generally reliable cause my Ibiza has been nothing but problems espically the main dealer haha
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    Quote Originally Posted by moggytom View Post
    As a fellow owner of a 55 plate high mileage TFSI Quattro, these are the issues I've had with mine. I bought it in Nov 11 with 108k miles, it's now done 130k. Paid £5k at time of purchase.
    DV knackered when car purchased
    Air bag light came on (had to do the pretensioner wiring fix under driver's seat).
    Oil pressure warning - pickup/strainer replaced
    Oil pressure warning again few months later, and bad sounds from engine - complete oil pump failure this time (££££)
    Boot wouldn't close in cold weather (had to dismantle latch mechanism and grease it)
    Engine management also light comes on intermittently (though no ill effects on performance)
    Other than that it's been fine. Most of the above are fairly minor, other than the oil pump failure which was buku dollars.
    Not trying to put you off, just telling you what I've had to sort out on mine!
    sidibear likes this.
    Audi A4 (B7) 2.0T FSI SE Quattro
    May 2013
    41
    Not putting me off haha if I could et one for 5k id have a grand left over for it anything did need doin ! Il be looking around the 100-110k miles mark
  1. FOR SALE: 08' S3 TFSI Quattro - Black - 5,000 MILES! - Big Spec
    By Ritch7 in forum For Sale/Wanted - Audi Cars
    Last Post: 3rd September 2011, 19:31
  2. Looking for a new 3.0 Quattro Sport as mine has died!
    By miv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2011, 20:43
  3. Hello - I'm looking for a A3 S Line 170 3DR
    By Agent_Trig in forum The Welcome Section
    Last Post: 17th February 2011, 18:29
  4. Anyone looking for an Avant TDI 140 S Line ?
    By Audi-do-dat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th March 2009, 18:52
  5. help; point to look out for
    By Toots in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2006, 12:49
