Hi all. I'm going to remove my glove box so I can fit the gps antenna for the rns-e, I was also thinking of doing the chilled glove box convertion as i have the glove box out . has anyone done this??? And is it definitely possible to do???
yes 2 ways
proper fridge
or just the pipe and pop the hole out in the glovebox
very easy to do
ive got the 6 disc changer in mine so will it still fit?
This will help.Its to do a b8 though, but will give you an idea.
AudiEnthusiasts Glove Box Cooler
Dont forget that it can heat the box as well as its dependant on your temperature setting for the whole car. Personally i wish that it was available for the b8, as well as having a cooling vent in the boot area both individually controlled. A bit irrelevant in any case as audi has poor aircon...just not cold enough
I have been looking on EKTA, looks like you may have to fit an additional pipe to feed the refrigerated glove box, but it looked simple enough, once the gove box is removed.
Anybody got any prices yet?
+1as my post 2
it does need a pipe to feed the box
even if i have mine on full heat the box stays cold
Eh? wonder how that works !!!!
extremely simple. It takes the air feed after the air conditioning matrix but before the heater matrix.
The take off to the cool box is after the air con matrix but before the heater matrix, so it's always cold.Eh? wonder how that works !!!!
Yep, that's the parts I used - 6 1/2 years ago!Found an old post Dave, assume they're the correct part numbers to do the full instal with the box aswel.
http://www.audi-sport.net/vb/a4-a4-cabriolet-s4-forum-b6-chassis/29450-glove-box-cool-box.html
The existing light is covered by the Cool Box insert, so I removed it (it's now the boot light in my Citroen C1!). The replacement I fitted on the RHS of the glovebox just in front of the Cool Box insert - the existing wires have the correct connector and are long enough to reach.Thanks to PetrolDave regarding the tip on the relocation of the Glove Box light.
Though exactly where in the Glove Box it is relocated too I,m not to sure yet, will have to wait till I have fitted the cool box to see exactly.
You probably wanna do a how to if im going to be having a go
