Sky InsuranceAH Fabrications
    Apr 2010
    346
    difference between 1.8t and 2.0t
    hi all,i picked up a 2007 a4 2.0t quattro sline that needs some work on the front passenger corner ,my brother in law has a 2007 a4 1.8t quattro s line,are they both the same bar the engine as it would by good to compare like for like when repairing it,
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    What repairs are you referring to; mechanical or bodywork?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Apr 2010
    346
    body work and suspension and anything else that might be in that area that possibly got damaged
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Should be fine. Worst case compare the part numbers on ETKA if you have it or know someone with it.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Apr 2010
    346
    I don't have etka can it be down loaded or where can I get it
    Apr 2010
    346
    took off most of the damaged parts tonight not looking to bad now,so anyone know how i can get my hands on etka
  1. What's the main difference between s line and none s line?
    By ikechukwu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2006, 12:10
  2. Replies: 4
    Last Post: 11th September 2006, 10:58
  3. difference between 210 s3 and 1.8tq engine? both 2000
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2006, 18:42
  4. Difference between dump valve and diverter valve
    By imported_Wicked666 in forum Tuning
    Last Post: 5th October 2005, 13:11
  5. Differences Between New SFG and S-Line SFG?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 08:31
