Results 1 to 9 of 9
    Mar 2013
    Southampton
    128
    Faulty rear parking sensor
    Hi,
    Recently having my A4 Cab. serviced at a local Audi specialist, they carried out a diagnostic on the front and rear parking sensors. It showed a faulty rear inner sensor.
    They quoted me £202 to supply a genuine Audi sensor, paint it and replace it.
    Having spent a lot of money recently buying the car etc, I would like to attempt this myself, could anyone give me any pointers, does the sensor replacement require the rear bumper to come off, if so how does it come off? or can I simply gain access to the sensor from underneath, any help or advise on this will be greatly appreciated.
    May 2011
    Suffolk
    310
    Hi Andy
    Not quite what you're asking but..... i fitted parking sensors to my Avant and yes, the bumper had to come off. I may be wrong but it would probably be too difficult for anyone to explain how to remove it as there are several nuts a clips in several location, only takes about 30 mins to remove
    There may be a 'how to' on here, if not google it.
    You may know which one it is thats faulty, but if you dont.....turn the ignition on, put it in reverse and put your ear to each sensor, you should hear a clicking noise coming fron each sensor, if you cant.....thats the knackerd one
    Hope this is some kind of help
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    i know on the saloon you can just get to the inner sensors and change them without bumper off
    my cabs on the ramps friday so ill have a look see if it can be done.
    Mar 2013
    Southampton
    128
    Hi,
    Thanks fpr the replies,
    Tuffy I had heard of the clicking sensor diagnosis but to be honest I always thought it was a bit of a myth to be honest, I,ll try it though see if it confirms the garage diagnosis thanks.
    Bez101, if you could have a quick look at yours when its on the ramp friday it would be really appreciated Thanks
    Oct 2012
    East Kilbride
    343
    I done 2 of mine on the B6.... got them off a nice chap on Evil bay land for £40 all in... (I think Audi was £100 each for them!)
    then I painted them myself, try and get the coats as thin as possible so that it doesn't confuse the sensor...
    the rear bumper has to come off, or at least undone to get a hand up and play about trying to replace them.... I just gave it all to my local Indy when it was in to get the water bottle fixed....
    May 2011
    Suffolk
    310
    Quote Originally Posted by Andy27168 View Post
    Hi,
    It really does work mate. I trapped a wire when I put my bumper back on which caused them not to work properly, I found out which one by the clicking test
    Oct 2012
    East Kilbride
    343
    forgot to say, yes the clicking test does work!!!
    even my Indy didn't believe me, until I told them which ones weren't working while waiting for them to plug their computer into the car... lol
    Oct 2013
    Hi all
    i need to replace a rear parking sensor!! I can reach the one I need to change from behind, but not sure if it should just pull out (from behind) I don't want to force it and break it!!!!!!!
    Feb 2013
    Wiltshire
    346
    there are two plastic flexible lugs that hold the sensor in place. They are very flexible and easy to move, but if you are at the wrong angle (not removed/loosened bumper) then they can be a pita. Also the sensor has to come through backwards a distance which means access is harder to get it out, or to uncouple the wiring. It really is much easier to remove the bumper. The rear on the saloon is 3 bolts each side from inside the boot and the wheel arch liners too. doesnt take long at all.
  1. Faulty rear park sensors
    By SirSpanky in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd July 2010, 18:02
  2. Rear Parking Sensors Faulty In Heavy Rain
    By S-Line_Wales in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th August 2008, 20:05
  3. Rear Parking Sensors - Faulty?
    By cheekeemonkey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2008, 22:09
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
