Results 1 to 14 of 14
Thread: Tyre wear
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    654
    Tyre wear
    Painted my brakes today and noticed the front tyres the inside edge has worn quite badly. There's about an inch where the tread has gone. Where as the rears are fine all over and the rest of the fronts have plenty of tread. Have only been on for about 12k. When I lowered it I have the tracking and camber checked as they said it was fine. Wheels are 8.0jx18h2 et43 with 235/40/18 tyres at 38 psi. Any ideas what may have caused this?
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    rizzini7's Avatar
    Jun 2011
    654
    P.s they're falken fk452's if it makes a difference
    Big Al's Avatar
    4wd + turbo = fun!
    May 2011
    West Midlands
    225
    Quote Originally Posted by rizzini7 View Post
    Front tyre inside edge wear is normally too much toe out or negative camber. Are the bushes on your front arms ok? Any play in either front wheel when jacked up in the air? The tyre pressure of 38psi seems very high too, check with a tyre shop/Audi. Try a different garage for another tracking check and suspension inspection. Good luck!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Joe Clooney's Avatar
    Sep 2012
    co.laois ireland
    54
    Sounds like tracking to me, maybe get it looked at again coz it shouldn't wear the inside of the tire like that.
    2007 Dolphin Grey B7 Avant 1.9 115 S Line
    rizzini7's Avatar
    Jun 2011
    654
    Cheers guys, cars getting new oil pump Saturday. So I'll get my mate to check the front over. When I had the camber checked they told me they couldn't adjust the front?? Guide on the car says 38psi. Keep in mind it's avant, quattro and v6 lump so assumed it was correct
    Sep 2012
    co.laois ireland
    54
    That's correct, front can't be adjusted. If both tyres are wearing the same amount on both sides, then it's not a bush or control arm, as they would never fail on both sides at the same time. So I say it's just your tracking needs a little adjustment.
    rizzini7's Avatar
    Jun 2011
    654
    Thanks mate, i'll get him to check and see what he thinks of the tyres. theres no wires etc showing. At least trackings cheaper then the 4 wheel alignment. Apart from maybe needing some new tyres. Suppose I've probably gotta change all four? Can't seem to find the fk452's anymore assume they've been superseded
    Molnboman's Avatar
    The joys of owning a Quattro Mate. Yep, all four boots will need to be done....
    Hope you get a result.
    A
    rizzini7's Avatar
    Jun 2011
    654
    Was talking to a lad at work today that's knows his stuff. He seems to think the lad that did the camber and 4 wheel alignment messed up and possibly set it up as a 2wd rather than 4wd. Would that make sense? Can I just get it adjusted at any garage £25 tracking jobby or does it need to go on the posh computer and be set up again £80 jobby?
    V6 Quatt's Avatar
    Feb 2008
    748
    Best to do 4 wheel alignment as 4 wheel drive or go back and get the garage to get it done properly
    Torque the Torque
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,346
    Don't go for the cheaper option. Chances are, it'll prove a false economy.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    rizzini7's Avatar
    Jun 2011
    654
    Probably can't take it back now. Been a year and cant find the print out. Just need to find out if the tyres are still legal before I book it in
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,600
    i would re do the tracking now everything is well settled in!
    oh, and vote on this mate! AUDI A4 B6 or B7 which is the best looking?
    rizzini7's Avatar
    Jun 2011
    654
    Well my mate confirmed tracking is out and everything else is fine. He's put the wheels on the back and reckons ill get another 8k out of them. Just need to find a decent garage for alignment now
  1. Tyre wear ,can you help please
    By domcj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2003, 19:02
  2. Tyre wear
    By speedyp in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 02:30
  3. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  4. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
