Results 1 to 10 of 10
    Oct 2011
    23
    RNSE - in mute - HELP! model 8E0 035 192 T
    Hi all,
    I have just recently changed my single din to a double din. All went well no problems.
    Purchased a RNSE unit from the bay - Part No. 8E0 035 192 T (says manufactured 2009)
    I also purchased the fackro loom to connect to my old wiring.
    The car had a parrot system which is still in.
    After its all linked up seems to work but the cars centre display shows telephone connection all the time and RNSE is in mute.
    Sat Nav works and says directions all through the speakers.
    I went to my local car hifi dealer and he says I have purchased the wrong RNSE unit and need an older model suitable for my car. He said my wiring loom will not accept this model.
    Is he right, as to me it appears all is ok but the parrot is putting it in mute?
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    Your RNS-E is fine. Trace back the MUTE wire from the parrot kit into the loom and follow it into the RNS-E making sure it hits the MUTE port in the RNS-E.
    Chances are the pin will be different on the RNS-E and the MUTE feed is getting a constant 12v from the wrong pin making it throw the MUTE up constantly.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Oct 2011
    23
    Thank you for that, I thought he was talking crap. Will try to trace the mute wire myself
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Quote Originally Posted by juddster View Post
    He's talking out of somewhere that the sun doesn't shine you can use any year of RNS-E in any year of Audi.
    As already said it sounds like something is pulling the MUTE line.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2011
    23
    Still having issues.
    I went back to the car and notice that the RNSE works fine without the ignition.
    As soon as I power up or even open a door and the lights come on its back into mute mode. The only way to clear it is to disconnect the plugs at the back of the unit and start again.
    Any one know a good auto electrician in Norfolk area as wiring issues are beyond me.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Which wiring looms did you buy? Some have dual mute wires connected to pin 11 of the D connector on the quadlock. One goes off to the 10 pin telephone ISO and the other one goes off to the power connector 8 pin ISO. Usually the mute issue is down to the latter connection, you can simply cut it out.
    Oct 2011
    23
    Yes, mine has a dual mute.
    I guess I go for a cut!
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Craig to the rescue
    Oct 2011
    23
    Cheers very much, you were spot on, the wire going to the 8 pin. Thanks again
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Now go back to the car audio shop with your music on full, get out, knock on the shop window and shout....YOUR A COCK
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
  1. SDS high retrofitted to mk2 RNSE (non factory SDS model)
    By wez3570 in forum Satellite Navigation
    Last Post: 31st March 2012, 15:00
  2. Audi 6 Disc CD Changer 8E0 035 111
    By slappy in forum For Sale/Wanted - Audi Parts
    Last Post: 16th March 2012, 17:48
  3. 8p0 035 192 h. Will this work with Audi B7? Quick response needed..
    By Khanage in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th January 2012, 22:03
  4. WILL THIS SAT NAV FIT IN MY AUDI A3 54 PLATE SLINE Part num: 8P0 035 192S
    By granny87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2011, 22:20
