Sky InsuranceEM Tuning
    Mar 2013
    36
    Vacuum hoses on BRD engine - valve cover not under vacuum?
    Evening Gents,
    Just checking the glow plugs on my 2.0 and when I removed the vacuum tube from the side of the valve cover, I could hear air sucking into the tube.
    This hose connects to the valve cover, but when I try to blow through the tube into the valve cover, it seems blocked. Question being, is it supposed to be, as I cant see what its supposed to do - blocked or not?
    Jan 2013
    Moray
    228
    It has a one way valve in it to prevent the air going back into the cover under pressure. When the engine is under boost.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Mar 2013
    36
    Thnaks for that Steve220. I also tried sucking on the hose sticking out of the cover and it seems blocked that way too. Have noticed air blowing out of the pinhole in the front left of the cover when the car is running - presume it's meant to do that?
    Do you know what the hose is meant to do? Thought it might be to sense if the cover is cracked? Also, do you know where the coolant temperature sensor is on one of these - damned if I can see / find it!
    Have the exact same car as you in Phantom Black BTW....without all the better bits you've bolted on!
  1. Replies: 0
    Last Post: 8th August 2012, 11:13
  2. Engine Valve cover gasket
    By Widemonkeys in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2011, 00:45
  3. Replies: 9
    Last Post: 15th July 2011, 00:31
  4. Where to buy Vacuum hose
    By awmw in forum Diesel forum
    Last Post: 23rd February 2007, 13:46
  5. Painted Engine Bay Covers
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 13:37
