Results 1 to 15 of 15
    Oct 2012
    11
    audi navigation plus
    hi does anybody know if i can link up a ps3 to the audi nav plus. i got the 2007 a4 b7 if this helps, and what about a dvd player?
    thanks
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    Yup.
    All you need as a RNS-E Multimedia Interface like this.
    Install it and code it for TV using VCDS.
    Using the RCA connectors you can connect the PS2 to the interface.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Oct 2012
    11
    thanks, do you know if this lead varies for the audi navigation plus stereo. and does it just plug straight into the stereo. as for coding how do do that, sorry im not good with this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,348
    Quote Originally Posted by cookie 1984 View Post
    What is your location please?
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Dec 2012
    Whiteley, Hampshire
    42
    Hmm.. I'd be interested in hearing how this works too..
    Audi A4 (B7) 2.0TDi S-Line Cabriolet
    NAV (RNS-E) / BOSE / FULL BLACK LEATHER / WINTER PACK
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    The interface has a 32-pin plug which plugs straight into the back of any RNS-E stereo.
    The RNS-E stereo then needs to be coded with VCDS (diagnostic tool) to be coded for the TV. It needs to be coded for the TV as the interface is a TV emulator, so when you select the TV option on the RNS-E, you'll get access to the interface.
    Oct 2012
    11
    i see but when u say diagnostic am i thinking the machine used for fault codes etc,
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Any device that can code into the ECU's of the vehicle. The most common tool that most of us in the scene use is called VCDS.
    Oct 2012
    11
    and if i use a diagnostic from a garage where do i get the vcds codes from?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Here's the coding, you just need to code it for TV: Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki
    Be aware that most diagnostics from a garage can't code into ECU's they can simply retrieve and clear fault codes. The only software that I'm aware of that can code is VCDS and VAS.
    Loads of members on the forum have VCDS, have a search for you closest one and they'll be able to code it for you.
    Oct 2012
    11
    Thanks for this, errr how much will it cost for someone to code it
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Totally depends on the individual. Most will do it for beer tokens.
    Oct 2012
    11
    thanks mate i think its took me like months to try and find out hoe you do it, sounds like you know your stuff
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Its not too bad tbh. Give me a shout if you need any advice.
    Oct 2012
    11
    will do thanks, ill let you know if i get stuck lol
  1. Audi Navigation Plus
    By Jeffreys in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2009, 15:26
  2. Audi Navigation Plus - Voice Guidance Issues?
    By Leenx in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2009, 11:52
  3. 2001 Audi S3 8L - Audi Navigation Plus options
    By Bojmobile in forum In-Car Entertainment
    Last Post: 16th September 2008, 19:56
  4. Audi Navigation Plus
    By Crazy_Eddie in forum In-Car Entertainment
    Last Post: 4th January 2008, 22:59
  5. audi navigation plus
    By beerglass in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2006, 20:44
