EM TuningMonster Motorsport
    Dec 2012
    16
    Loosing steering fluid?
    My b7 a4 has started loosing power steering fluid, where best place to start checking?
    my car is "decked" with the bumper more less on the ground lol, is there any pipes close to the ground which I could of damaged? Or any near the wheels as I have 19s on which could rub against them?
    Had to top it up twice within 400 miles if that helps
    thanks for any info guys
    Dec 2012
    16
    Any help?
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Power steering pump might need replacing, mine went on my 2.0TFSI Q. I had vibrations in the steering and kept loosing fluid.
    2008 A5 3.0TDI
    Jan 2013
    Moray
    228
    Get the car on a set of ramps, remove the under tray and physically look. There's no point in getting paranoid and guessing, you need to look for the leak physically then go from there.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
  1. Correct Power Steering Fluid for an 96 A4?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2004, 08:08
  2. Which Power Steering Fluid?
    By caminator in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2004, 21:06
  3. Power Steering Fluid
    By TrueNilbog in forum TT/TT-S/TT-RS Forum
    Last Post: 3rd October 2004, 02:24
  4. Power Steering Fluid Leaking A4 2.8 1997
    By bradmcw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2004, 12:53
  5. Power Steering Fluid
    By blued in forum General Technical / How To
    Last Post: 28th August 2003, 13:23
