Volks AutosBadger5
    Apr 2013
    25
    Parking sensor front failed
    If i put the car in reverse (engine off) and listen to the sensors, the front mid left sensor is silent. I get a solid beep in the car which i guess indicates theres an issue but every now and then it works.
    My question is do i just buy and fit a new sensor or is it worth checking any wiring first?
    Heres the relevant scan result.
    Thanks for your time.
    Warren.
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
    Component: Parkhilfe 8-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802120619
    Coding: 0001124
    Shop #: WSC 00672 785 00200
    VCID: 32616B6CAE347EE
    1 Fault Found:
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 13
    Reset counter: 240
    Time Indication: 0
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    By all means check the wiring though this will be very unlikely. Sensors aren't cheap mind ~£82 each!
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  1. Anybodys parking sensors failed?
    By RyanJonS4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th April 2009, 15:53
  2. Faulty front parking sensor
    By jvbates in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2008, 17:07
  3. Pic request - Front parking sensor switch
    By JohnS3 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th December 2007, 17:40
  4. Front Parking Sensors
    By vinesh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2007, 23:19
  5. Front parking Sensor...annoying??
    By willie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th January 2007, 18:16
