Chris NottSky Insurance
    Apr 2013
    Problems with A4 Cab 3.0TDI S-line 2006
    About a year ago, i noticed excessive smoke from the exhaust, only visible though in cold weather. Car went back to Audi dealer twice, but they were unable to idenitfy problem. When issue got worse they told me it was a sensor in the exhaust, which got changed. (cost >£500). Following winter, same issue, but also noticed slight growling noise from enginer bay following 70K service. Car went back to Audi, engine stripped down and cleaned due to excessive build up of carbon !. (another £500). When car returned problem still exists.
    Back to Audi again; following 3 days of investigation by Audi Dealer, i was told that the smoking issue was caused by failing injectors and that the growling noise was due to a problem with the turbo and that all would need to be replaced at a cost of £5800. Managed to negotaite this down to £2500 with good will gesture from Audi. Work has been undetraken, but still getting the low level growling noise. Audi dealer admit they can hear the noise, but cant identify the root cause. Have told me to run it for another 1K miles and see what happens !.
    Just wondering if any of this sounds familar to anyone with an A4 3.00TDI and if so, what was the root cause ?
    thanks
    Mr-C's Avatar
    Feb 2013
    Chorley
    163
    Me thinks you need to find a good indy
  1. clutch problems with 2.0tdi 140 remaps??
    By rickyt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2011, 21:28
  2. any problems with a4 cabs 2006
    By bearder2006 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th April 2010, 21:48
  3. Strange problem with A3 2.0TDI.........
    By Dr.Mumby_RS6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2010, 17:07
  4. Problems with roof on A4 Cab
    By chiefwiggumpi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th October 2009, 12:31
  5. A4 2.5 Cab 55 plate problem with clutch
    By Blokeinpub in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th March 2007, 22:19
