Badger5AH Fabrications
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    192
    turbo laggggggggg
    hi can someone shed some light on what sort of gap, if indeed any should the turbo kick in ? i've a 2.0tdi s-line, this is the first time ive had a diesel car although i have driven many, and have always thought there should be a small lag when you sink the boot before it kicks in and then pulls like a horse, or should it be more or less instant ?
    and what can i look for and check
    thanks Noz
    Molnboman's Avatar
    I never had an Audi oil burner but have had plenty of Fords and GM diesels. It depends how you determine turbo lag...I thought that even on the B7's the engine lag shouldn't be that noticeable, and thought it applied to the older diesel engines. Has your car been recently serviced or have you had a diagnostic check done at your friendly local garage. That may throw up a few clues to the explanation of any turbo lag you may be experiencing.
    A
    Jan 2013
    Moray
    228
    You shouldn't feel lag, it's should be progressive as your car uses variable vane.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    192
    thanks guys think i will get a service, i know its due in about 1400 miles but might get it done early and mention it to them to see what they find
    Molnboman's Avatar
    [QUOTE=NOZ;1852268]thanks guys think i will get a service, i know its due in about 1400 miles but might get it done early and mention it to them to see what they find
    Well I guess, depending on what you are planning to do you may as well get it all done in a oner!....I would be asking the garage to run a good diagnostic check ( which they will do as standard practice anyway ) and explain to them you feel it's a bit sluggish when you boot it....if you have a good relationship wae your garage they should be able to explain what the issue may be if they can find anything.
    All the best
    A
    Jan 2013
    Moray
    228
    It could also be your egr valve clogged up. Seems as if some problems for late boost come down to this annoying little item on the engine.
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
