Results 1 to 7 of 7
    Nov 2012
    York
    36
    2.0 tdi 170, do you get a whoosh?
    Hi,
    Do you get a slight whistle when boost comes in on your 2.0tdi 170 engine?
    I've noticed it ever since i bought the car and thought it was just normal (i do have a K&N panel filter fitted).
    Now im starting to wonder whether it should be doing it or not. Its only really noticeable with the window open.
    The whoosh starts from around 1300-1500rpm, but what i have noticed recently is that, say, you let off at 2000rpm in gear, the whoosh settles down a little for a second but then comes back again a little higher until the revs drop.
    Is this normal or not? There is a bit of greyish smoke looking in the rear mirror when you put your foot down to overtake, more so the first time and it seems to die down after the first couple of blasts. It has a DPF fitted too so i didn't think there shoulw be anything?!
    MOT tomorrow morning so im a little worried, how much smoke is too much?
    Nov 2012
    York
    36
    Bump, any help on this?
    Smoke seems to have died down after a good run last night. Still unsure whether the turbo noise is normal or whether there may be a leak? Do you get a whistle from low revs?
    Jun 2011
    NW London
    141
    I get a little whosh when I let off the pedal, but I have a dpf delete and remap. Has your car been remapped?
    Audi A4 2lt 170 TDI Quattro s-line, B7, BRD engine code. Mods so far; cruise control, DPF delete, EGR delete, unicorn remap, B5 perches, RS4 rear arb, RNSE with SDS, 2013 maps with speed cams, aux in, powermax remanufactured balancer, Sachs SRE organic clutch and pressure plate with LUK flywheel. Mods to do; s4 break upgrade, glove box fridge perhaps...
    Jan 2013
    Moray
    228
    You might be hearing the turbo a little louder due to the panel filter. Giving the car a good hard run would hopefully clean out the dpf, especially if you've been doing short journeys.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Nov 2012
    York
    36
    No the car is standard other than the filter, although i think i could still hear the slight whistle before. The turbo has been replaced in the past but just for a standard unit. Im wanting to get a remap and dpf/egr delete in the future but need to make sure there's no other problems that will surface afterwards.
    I do try and keep short journeys to a minimum and make sure i take it out once a week for a good motorway blast, maybe the smoke i am getting is from the regens. I do sometimes feel a little stutter from the engine.
    I kept the car in boost this morning and didn't notice any smoke, so hopefully it passes the smoke test. I do need a new tyre though, dropped it off at my indy to check over and there is a split on the inside, and a wheel nut missing
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    You will hear it more with a pannel filter, and more so with DPF removed.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    nbray67's Avatar
    Mar 2013
    Retford, Nott's
    129
    3rd gear 50mph for 15mins is how the Audi garage told us was the best way of clearing any DPF issues.
  1. TDI 170 Decat downpipe where to get from?
    By RedDejavu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2011, 13:49
  2. What remaps can you get for 2.5 TDI?
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2010, 09:58
  3. ALLROAD 2.5 TDI MPG HOW MANY DO YOU GET!
    By rallyingarron in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th February 2008, 10:19
  4. How do you get a 2.0 TDI DSG off the line quickly
    By stevehsv868 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2007, 14:39
  5. Should i get DSG or Manual / 2WD or Quattro on new A3 Tdi 170 S-Line
    By grimsa in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2007, 17:08
