EM TuningVolks Autos
    Sep 2012
    16
    Audi b7 a4 headlight bulbs
    I am trying t replace my headlight and got to the bulbs in less than a minute but I cannot for the life of me get the bulbs out any advice?
    Dec 2012
    16
    Pull the back plug out, then squeeze the metal bracket holding the bulb in then it should fall open, and remove the bulb
    Sep 2012
    16
    The plug is off and you mean squeeze the metal ring around the plastic holder and the bulb should come out with a good pull ?
    Jun 2011
    Manchester
    248
    They are a right royal pain the backside but will come out eventually with lots of wiggling. (wiggling of the bulbs that is!)
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
  1. Audi A3 2009>> halogen headlight bulb change
    By erq55 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 21:59
  2. Audi Headlight bulb
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2011, 14:48
  3. Can the multi led headlight bulbs be fitted to the std. audi lights?
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th October 2010, 16:10
  4. Audi A4 avant airbag light after headlight bulb change!
    By fabtdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2010, 07:14
  5. Civic Headlight bulb removal??
    By Naresh in forum Other Brands & Models
    Last Post: 26th June 2003, 13:12
