Badger5Sky Insurance
    Apr 2013
    140
    Irregular Vibrations at idle
    Hi all,
    Was sat in my car stationary today and slowly went through the rev range and between about 1100 to 1800 revs you can feel the 'rhythm' of the engine change it doesn't sound any different as you progressive, nor is there any clunking rattling etc. It is very very hard to notice, it could be just the natural characteristics of the engine and I'm just being paranoid.
    Engaging, disengaging the clutch in neutral doesn't have any effect either
    Any ideas what it could be? It's a 2.0 tdi S-line Cabriolet 2006 with 69k on the clock
    The needle isn't up and down or anything, the revs progress smoothly.
    You can only just sort of feel it, the sensation off balance wheel except stationary.
    Cheers, James
    May 2011
    Suffolk
    310
    I have a slight vibration run through my 170 TDI when it idles. I can watch the gear stick shake a little then stop, then shake again, can feel it right through the car
    Apr 2013
    140
    Its only avery slight, you cant really see it in the gear stick. But my car does often start up and go into what i think is limp mode and limits itself to 3000revs
    Molnboman's Avatar
    Does you feel it in first and second gear when you pull away. If it's only when it's stationary, then it may be nuffink....if you feel it when moving...it could be your flywheel starting to say bye bye!...you have a manual right?
    BR
    A
  1. audi a4 2.0 saloon 57reg / Vibration at idle?
    By omar7988 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th January 2011, 12:48
  2. Allroad vibrates when idle (at lights etc) Is this a Flywheel problem?
    By buftonian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th January 2011, 20:24
  3. Vibration at idle when engine is warm.
    By PhatBob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2009, 10:43
  4. Vibration at idle, flywheel?
    By kosmickid in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th October 2008, 07:58
  5. Low judder/vibration at idle
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2008, 16:35
