EM TuningSky Insurance
    chrisa4quat's Avatar
    Sep 2004
    897
    Rs4 button start in to b7, does it need
    A relay or anything or is it ok to just be wired straight in? Thanks
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    carl-1968's Avatar
    May 2012
    Nottingham
    450
    you first Chris, if it works I'll have a go lol, just put it on my "to do" list
    Sep 2004
    897
    I've already done it Carl but the button failed. I was wondering if it was something I have or haven't done or whether its just a faulty button
    mehtaman's Avatar
    Feb 2012
    Wembley, Middlesex
    63
    Not sure if this helps but I've had this eBay item in my watch list for ages:
    http://www.ebay.co.uk/itm/RS4-kit-bo...p2047675.l2557
    At the bottom of the description there are two links to some install instructions.
    Hope that helps
    | Audi A4/B7 2007 | 2.0TDi | S-Line | RNS-E | 18" S-Line Alloys |
    | Modifications | Pure Highway 300Di DAB | BlueFin Remap |
    Sep 2004
    897
    There looks like a relay there? I have both the instructions thank you buy nowhere does it state having a relay
    olethalb's Avatar
    Aug 2012
    312
    i used a richbrook one in mine as i fitted it to my B6 flip over cigar lighter
    the DTM loom is a bit more old school with starter wire so i'd advise a relay or you'll be having full current going through the switch / button on cranking
    you can use this as it's pretty close to our set up
    Google Image Result for http://lh3.ggpht.com/taplive/SE3-Lz0ay4I/AAAAAAAABcI/1AJLDDaE9VA/s800/Starter%20Button.JPG
    and here's mine
  1. A3 1.8t won't always start and when it does it stalls after a few seconds
    By Tony toss in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 19:55
  2. Building an RS4 alternative - Start with an S4 or a 2.0TFSI??
    By Bad Sir Culation in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th November 2011, 16:47
  3. 18" RS4's fitted..Does it need lowered now ?
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2010, 10:44
  4. RS4 Engine start button on S3
    By klik in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2008, 18:32
  5. Engine Push Button Start?
    By N8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2008, 19:24
