Volks AutosJMB Retrofits
Results 1 to 32 of 32
Like Tree2Likes
  • 1 Post By Newbos
  • 1 Post By jdp1962
Thread: Programming Cruise control
    Newbos's Avatar
    Sep 2012
    115
    Hi guys
    I have fitted my cruise stalk today and lower column trim and that was nice and easy. I have come round to coding it and as I have *cough* *cough* copy I can't do some of it. I can enable it in steering wheel module but I can't do the abs brakes and steering angle sensor bit, so anyone in the lincs area fancy doing me a favour for some cash or beer tokens?
    Cheers Si
    Newbos's Avatar
    Sep 2012
    115
    No one in my area? I'm sure it will take all of 10mins to do. Easy money for someone.
    chrisa4quat's Avatar
    Sep 2004
    897
    There maybe noone in the area. What other areas are you likely to be in over next month or so? May give people more opportunity to help you out
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Newbos's Avatar
    Sep 2012
    115
    Well I work anywhere from Leicester to Rotherham, so does that appeal to anyone?
    Sep 2004
    897
    I'm in Nottingham I have never coded one but I'm sure it's easy enough
    Newbos's Avatar
    Sep 2012
    115
    Have you got full legit copy of vcds? And CAN ready?
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,608
    You shouldn't need to do the ABS bit, not in a B7. You should be fine coding the Steering Wheel and Engine only.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    sheffield
    Newbos's Avatar
    Sep 2012
    115
    Well there are 4 parts to programming as far as I can see
    1. Enable cruise in steering wheel bit (16)
    2. Login into brakes module (03)
    3. Steering wheel angle sensor
    4. Code the engine for cruise (01)
    So you think I don't have to do part 2?
    Penninepete1's Avatar
    Jan 2013
    14
    Nope, you don't need to code the abs brakes module, I fitted CC about a month ago on my B7 and didn't need to.
    2007 "57" A4 Avant 2.0TDI S-line 170
    Newbos's Avatar
    Sep 2012
    115
    The problem I have is my vcds is 11.11.3 and when I load up the individual bits the login button is greyed out!!!
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    If you can get the coding in the Steering Wheel and Engine done then you'll be able to do it yourself.
    Sep 2004
    897
    I am manager at a VAG specialist in Nottingham so I can do it if interested Si?
    Newbos's Avatar
    Sep 2012
    115
    I'll give it another go, but if I get know where I'll pm you Chris.
    Simon
    Newbos's Avatar
    Sep 2012
    115
    silly question time - What is the "Steering Angle Sensor (G85) Calibration" and why is it needed in this install of cruise?
    Newbos's Avatar
    Sep 2012
    115
    Right I don't think I can complete. Even though you say I don't have to do the 03 abs brakes I must have to do something as its not working and I have now also activated cruise on 01 engine. However the reason I can't access 03 abs brakes to code is because my login - 11 button is greyed out. Security access? Basic settings?
    I know most of that will make no sense, but the experts on here will hopefully understand.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    If you have activated the Cruise in 16-Steering Wheel and 01-Engine then that should be enough for the B7.
    Now you need to do some fault finding.
    Go back into 01-Engine and go to 08-Measuring Blocks and go to group 006.
    From this group you'll see a binary output something like this '000000' (can't remember exactly).
    Now have a play with the Cruise Control stalk, do the binary values change? If so, the coding is completely fine. Dip the clutch, does a single 0 value change to 1? If not, then you need to replace your clutch switch.
    If there are no changed values when playing the with the cruise stalk then there is a problem with the coding.
    The steering angle calibration is done when you start driving. On the B7's this is done without loggin into the 03-ABS controller. Simple as full lock left, full lock right, back to middle, drive in straight line and the traction control light should go off (meaning the steering angle calibration is complete).
    Newbos's Avatar
    Sep 2012
    115
    Well I have put laptop away now, but I'm worried now cos I have definitely activated it in steering wheel and engine.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    Don't worry, it's all fixable. Give it a whirl tomorrow checking the meas blocks and see what you can see,
    Newbos's Avatar
    Sep 2012
    115
    Hi mate
    Right done that and the only thing that doesn't happen is when I press the clutch? (no values change) What is a clutch switch? Easy to install? Have you got a part no?
    Simon
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    Good work mate. Clutch switch is a very common fault on the B7 and its easy to replace.
    1) Remove drivers side fuse box cover
    2) Remove driver side under dash panel (3x 8mm bolts) unplugging the OBD port and footwell lights (if fitted)
    3) Look near the clutch pedal and you'll see a device that looks like this. The plunger from the switch extends as the clutch is pressed, so you should be able to find it easily
    4) Unplug the electrical connector from the clutch switch
    5) Twist 45 degrees (will only go one way)
    6) Remove and replace and reverse all above. There is no correct way to replace like there is with a brake switch, as long as it clicks in place and the plunger extends with the clutch pedal etc.
    Part number for the clutch switch is 8E0 927 189 B - £13.74
    Did you clear the Steering Angle Sensor error too? You must have if you don't have any lights on the dash?
    Newbos's Avatar
    Sep 2012
    115
    Cheers for great reply mate. Will order switch ASAP. Yeah cleared all dtc's
    Really appreciate your help!
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    No problem mate, anytime.
    Newbos's Avatar
    Sep 2012
    115
    Is that part no for both the b6 and b7 because on eBay that part no lists switches for the b6.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    Yup, fitted to loads of models.
    The part number actually supercedes to 7H0 927 189, so you could also search for that part too. (they're both the same part, doesn't matter which one you get).
    Newbos's Avatar
    Sep 2012
    115
    Cheers mate
  28. #27
    Newbos's Avatar
    Sep 2012
    115
    Got my switch, will fit it tonight. Will then do test again. After this i assume aslong as the value changes im good to go?
  29. #28
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    Yeah. When you fitted it it should be good to go.
    If it still doesn't work, check the measuring block again and see if the value changes, if it doesn't then its a electrical fault to the switch (which I've came across once before)
  30. #29
    Newbos's Avatar
    Sep 2012
    115
    Cheers buddy!
  31. #30
    Newbos's Avatar
    Sep 2012
    115
    Switch took 5 minutes to fit and I now have cruise. Really appreciate everyone's help.
    Si
    jdp1962 likes this.
  32. #31
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    Glad you got it sorted
  33. #32
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Newbos View Post
    Si
    I love this thread; it's everything this forum is about.
    Newbos likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  1. cruise control retro-fit
    By yoda01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2010, 15:11
  2. CRUISE CONTROL, CAN IT BE DONE?
    By blackwood in forum General Technical / How To
    Last Post: 2nd October 2004, 15:20
  3. Retro fitting cruise control
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2004, 10:35
  4. Cruise Control,
    By t955daytona in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:45
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
