Monster MotorsportChris Nott
Results 1 to 9 of 9
    Mar 2012
    North Wales
    121
    Rattling wastegate
    Hello everybody. As title says I seem to have a rattling wastegate on my turbo. Does anyone know what the reason this might be and is it an easy fix? also what problems this could give me if I keep on driving the car in this condition?? My car is a 2.0tfsi 220bhp bul coded engine ..Thanks Paul....
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    I would check your turbo boost levels, to avoid engine damage.
    Have you a boost gauge fitted?
    Either way, I would get the car checked on a local dyno with VCDS check too.
    listings, reviews & ratings of Rolling Roads | Dynometers | 2wd | 4wd | motorcycles | the Rolling Road Register
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Mar 2012
    North Wales
    121
    Ok Big Al. Thanks for that. I don,t have a boost gauge fitted.So I will try and get it sorted at my local garage. Hopefully they can detect any issues with the turbo wastegate..Is the waste gate easy to adjust without a boost gauge? Cheers buddy..
    Apr 2008
    Coventry
    10
    I've got the same engine and by the sounds of it, same problem. I was told that the only solution is to replace the turbo. Had the problem for about 18 months now with no further issues or change in performance. Would love to find a cheaper solution though !
    Mar 2012
    North Wales
    121
    Hi Kev. I hope that isn,t the case.As for the performance I think it has affected my car.It seems to have lost a bit of low end power.Not sure if the wastegate issue has caused this?.I have seen on ebay wastegate parts for the k03s turbo between £50.00 and over £100.00. Without knowing the right part number I am stumped as to which one to buy
    Jan 2009
    150
    The spring in the actuator has either weakens or broken. All that's required is an actuator.
    Mar 2012
    North Wales
    121
    Hi Gaz. Any idea on part numbers or price?? Anyone else if they know?? Cheers
    Jan 2009
    150
    Sorry mate I don't. Don't have a dealers tell you it's the turbo and waist your money.
    Mar 2012
    North Wales
    121
    Ok cheers buddie. It,s not a nice feeling when you get "shafted" by the stealers
  1. Rattle on acceleration, occasional exhaust pop.
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2003, 09:46
  2. Wastegate actuator
    By Steve1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2003, 23:38
  3. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
  4. Rattle?
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2003, 18:32
  5. Annoying Rattle
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 22:15
