Badger5Chris Nott
Like Tree1Likes
  • 1 Post By RMH1A4cab
Thread: Fitting dis, cruise and mfsw HELP!
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    727
    Right I'm looking to fit dis, cruise control and a mfsw to my avant.
    The parts I have so far are:
    Dis stalk 4e0953503c
    Cruise stalk 4e0953521
    Steering ecu 8e0953549q
    Mf wheel 8e0419091 ee vdu (b7 3 spoke)
    Have a spare lower trim to try and cut
    My airbag fitted to a b7 3 spoke nonmfsw
    From what I've found on the site the parts and airbag should be fine.
    But I can't find a definitive answer to whether I need a new slip ring? If so what part number do I require??
    Thank you
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    rizzini7's Avatar
    Jun 2011
    727
    Ok, so after a bit more looking it seems I probably need the slip ring aswel. Which part numbers fit? Also, do I need an airbag loom?
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    ESD1711 likes this.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    rizzini7's Avatar
    Jun 2011
    727
    Ok, appears I need slip ring and loom as well. Slip ring number that seems to regularly used 4E0953541A or B. Which I assume is for the A6 should it not be 8E0953541 A or B for the A4
    Apparently A is for paddle shift and B for manual. Quite a few A models on eBay and other people seem to use them. So am I ok using the A one even though mines a manual?
    Loom 4F0 971 589A can't seem to find on eBay. Can't 100% find out if I need it as some seem to while others don't
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Try the German ebay, thats where I found mine.
  1. Fitting cruise and DIS to my B6, how much?
    By N11KDJ in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th June 2012, 14:06
  2. cruise and dis
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2010, 13:24
  3. Fitting DIS and Cruise
    By BlackQuat in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2010, 18:26
  4. Anyone done a Cruise and DIS Retrofit?
    By chrisash32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 15:52
  5. New cruise and PDC fitted!
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2008, 12:31
