Hi All,
I'm looking for some help with regards to a clutch on my A4 B7 2.7TDI V6 engine code BPP, gearbox code: HXR
I'm aware that the RS4 clutch is the same (shared) between the 3.0tdi (manual) and RS4 - Both of which use a dual mass flywheel. I think the RS4 uses a 10bolt flywheel (not sure on dimensions) THREAD HERE (does the 2.7 and the 3.0 TDi share the same)
Can one see (etka) or know if the RS4 and 3.0TDi share the same flywheel? or if these are interchangeable.
I've been told already that an RS4 clutch stage 3 will work with a singlemass fly wheel from sach - HOWEVER, I can't see this single mass flywheel for my engine anywhere.
If I can work out that the RS4 flywheel and clutch would bolt on to mine - I can simply buy a complete RS4 stage three flywheel and clutch package - SORTED! rather than some flywheel I can't source
Hope that makes sense, look forward to anyhelp
