JMB RetrofitsEM Tuning
Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By RMH1A4cab
Thread: Adjusting front s line bumper
    May 2011
    Suffolk
    310
    Hi guys.
    Im sure i saw a thread somewhere, which i cant find now, that its possible to adjust the gap where the the bumper meets the bonnet either side of the grill, i have around a 15mm unsightly gap
    I think its possible to close this up, but does the bumper need to be totally removed to do this??
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Yes. You need to remove the bumper and then adjust the two supports which it sits on. They are threaded I believe and you just need to turn them the right way.
    Quite a few guides about the place if you give it a search. Often paired with changing headlights (bumper-off job)
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,002
    I need this done on mine, but can't do it myself. Anyone fancy a go for beer tokens?
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    its easy try it yourself
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Largely gave up trying to fix mine, just couldn't quite do it and have the lights fit in
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    I adjusted mine like this without even taking the bumper off..
    DIY: Bumper/Hood Gap Adjustment (after bumper removal)
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
    May 2011
    Suffolk
    310
    Quote Originally Posted by Tiffy View Post
    Thanks Tiffy. So am i right in thinking you adjusted yours with a pair of long nose pliers????
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,002
    I have a spine issue.
    JSD 2.59
    Synergy-Solutions
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Tuffy...
    I used a long bar and torx bit like in the first picture....tyrned and the bumper rose up a bit....job done
    Privacy Glass
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    191
    Tuffy...
    I used a long bar and torx bit like in the first picture....turned and the bumper rose up a bit....job done
    so you just insert the torx and turn to adjust the height HMMMM sounds to easy to be true ! what size torx is it ?
    thanks in advance
    Oct 2012
    492
    is this possible on the 56 plate s line bumper as the one in the guide loocks like a facelift 09 onwards?
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Quote Originally Posted by NOZ View Post
    thanks in advance
    Exactly what i did......I Think it was a T20 or 25
    Privacy Glass
    Rastamouse's Avatar
    Welsh Audi Nut
    Aug 2011
    351
    Did mine not long ago ,quite straight forward,believe it was aT35 torx i used.bout a set of 4 long series torx screwdrivers from the bay for bout a fiver,did the job a treat. Heres a few images. Of mine before and after adjusting.
    http://http://www.audi-sport.net/vb/...d.php?t=172632
    rs4 grill with black wrapped surround,lowered 50/40 on weitec springs,rs4 fog grills,DRL headlights,18" rs4 alloys,Remapped to 175bhp, double din conversion with kenwood dnx7220 headunit,tinted windows,carbon wrapped interior,arm rest retrofit,Led interior lights,ambient light retrofit.Rs4 Pedals,Chrome wing mirrors.
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    191
    so i set about mine yesterday, got all the necessary tools etc got the right side sorted all nicely fitting perfect, till i went to adjust the other side and found that the torx screw had been rounded off by obviously the previous owner, so back to the other side and back to adjusting it. So although now its not how i want it to sit but at least the gaps are now matching.So next time the bumper comes off i will see about replacing the said torx.
    Anybody thinking about adjusting the bumper it really couldn't be any easier clockwise to raise, anti clockwise to lower simples !!
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,002
    Just had a look at mine and cannot see the adjusters, bumper lights and grille are all in place. Am I missing something or do I need to start taking bits off to see them?
    JSD 2.59
    Synergy-Solutions
    North East
    607
    I am with you Sidibear, can't see the adjusters on mine either ?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    You need long torx bits. There are two holes, one either side of the grille looking down on it with the bonnet up.
    Nathan
    North East
    607
    I'll check mine out tomorrow with a torch ..............
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Follow this link, first and second picture for height adjuster location.
    sidibear likes this.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,002
    Yay, found the hole and poked a stick in it and found I need something about 8" long (Cue carry on type innuendo jokes).
    What size bit do I need?
    JSD 2.59
    Synergy-Solutions
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    191
    Quote Originally Posted by RMH1A4cab View Post
    that's the link i used perfect
    North East
    607
    Quote Originally Posted by Paul B7 View Post
    Found them !
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by sidibear View Post
    Ooooh, Matron!
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    May 2011
    Suffolk
    310
    Had the car in the workshop yesterday, had a quick look..... looks like one of my adjusting bolts is actually missing!
  1. s line front and rear bumper respray
    By timontour in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2012, 22:45
  2. WANTED a4 b7 bonnet, 2.0 tdi front panel rad pack etc, s line bumper, airbag set
    By Lee Applin in forum For Sale/Wanted - Audi Parts
    Last Post: 1st June 2012, 14:41
  3. A4 B6 Front s line complete bumper wanted please
    By Quattro180 in forum For Sale/Wanted - Audi Parts
    Last Post: 5th May 2011, 10:57
  4. Do the carbon front stick on splitters fit the s line bumper
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th July 2010, 23:37
  5. Front upper s line bumper
    By scottie 81 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2010, 11:30
