EM TuningSky Insurance
    Apr 2013
    140
    Headlights dimming on startup
    Hi guys,
    Noticed lately that when I start my car for the first 1-2 minutes the headlights go dim and then back to full brightness again. Its quite hard to see sometimes but it is accompanied with a gentle clicking noise from the dash?
    Its a 2006 2.0tdi cabriolet S-line
    Cheers, James
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Could be the headlight control unit under the steering column, need to go on VCDS first to check voltage to see if it is at fault.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Jan 2012
    100
    have you measured your battery?i had the same problem but it mainly happened when i had my heater on and the lights on at the same time.changed the battery and all good
  1. Really dim dipped headlights
    By x1nick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 21:36
  2. A4 B5 facelift dim headlights
    By lothian in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2009, 18:01
  3. dim headlights on a3
    By ste_1210 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2008, 13:06
  4. A4 Headlights
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 12:23
  5. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
