Volks AutosChris Nott
    Apr 2013
    Whining noise from transmission / wheels at only 40k
    Hi, I hope someone can help
    I have an Audi A4 Avant 2.0 fsi, 2005, 6 speed, only 40k miles on it - when I bought it last summer at only 30k miles it was fine.
    It has now developed a strange whining noise starting at about 30 mph and getting louder and rising with speed so that at 70 it is pretty loud and intrusive.
    The noise is road speed related not engine revs related.
    You can hear it in all gears and in neutral, and with the clutch in or out and when coasting at speed with the engine revs low.
    The noise does not really change when swerving left to right when coasting in neutral (so I dont think its a wheel bearing??)
    AT 60mph it is really quite loud and is on all road surfaces. I dont think it is tyres as all 4 were new in December and I couldnt hear the noise then - the new tyres are top of the range jobs and I selected them as they had the best noise rating.
    Any ideas what it is likely to be?
    How can something mechanical go at 40k miles and I am absolutely certian the mileage is genuine ....... Many thanks.
    It is possible I can also feel a vibration on the pedals / steering wheel, but that could be my immagination.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Bearings are the first thing I'd check if you've rolled out tires,gearbox ect.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
  1. Whining noise - Its the wheel bearing right?
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2012, 08:56
  2. Whining Noise from back of car
    By bezza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2010, 12:16
  3. Whine noise from front end - speed related
    By 1210tech in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2010, 20:45
  4. Funny noise from front wheels?
    By TDI-line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2008, 07:33
  5. Noise from rear wheel - Tyre problem ? Help
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2007, 19:22
