Badger5JMB Retrofits
Results 1 to 10 of 10
    Apr 2013
    Tiptronic problem
    A4 3.0 quattro 78,000 miles
    2005 tiptronic transmission problem.
    No reverse gear. car stuck in limp mode.
    Car been in garage today. Fault codes thrown up do not indicate any specific problem. Worst fear is that it is the module within the gearbox.
    The fluid level is fine. Has anyone heard of a similar problem? Will a fluid change help matters? Any advice would be great.
    Jun 2011
    Great Melton Norfolk
    1,356
    did they connect to gearbox ECU? they can check if the solenoids are working or not, Did it say intermittent signal?
    What did they use to check the codes with?
    Jun 2011
    1,356
    Do you get the PRND flashing on the dash clocks?
    Apr 2013
    PRND not flashing but all lit up a solid line.
    Bosch diagnostic through the obd i think
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    I have recently had dsg problems on my 3.2v6 a3 and the fault code I got is-
    17085 - Transm. Control Module Range/Performance (SAE) or Control Module Defective (VAG)
    P0701 - 004 - No Signal/Communication - Intermittent
    I got the dsg serviced and I thought everything was ok until it jumped out of gear and the dis prnds started flashing.
    Put the car in neutral and turned the car off then restarted it and the dis was not flashing and I could select the gears again but sometimes only for a short period of time and then other times it will not do it again for the rest of the day.
    I posted in a thread about this earlier today there is a company within that thread that can rework your gearbox ecu.
    Company
    http://www.ecutesting.com/
    Thread
    Fault code 17085 - P0701 - Mechatronic issues - any ideas?
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    27,129
    Also calibrating the gearbox with vcds or dealer is a must before condemning.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    NHN would have thanked you but on iPhone so a like will need to do.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,703
    Quote Originally Posted by shariain View Post
    I've thanked him for you.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Well since getting the dsg serviced it has only jumped out of gear once so hopefully that's my problem sorted. Going to go back to the Indy and find out about getting the dsg reset. Just hope that's me sorted but no doubt I have spoke to soon.
    Apr 2013
    Car is now in Eurotronic in Rosyth...............so fingers crossed. Everyone i speak to says it could be gearbox module. I don't know how
    much how much of a repair that is. But it will be sore i'm sure
