AH FabricationsVolks Autos
Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
Like Tree3Likes
Thread: Eibach Springs arrived
  1. #41
    Jan 2013
    Moray
    228
    Mac, out of interest, on fitting is there a nut holding the centre shaft of the shock to the top mount or is it attached another way? Only reason I ask is I think there maybe another way of fitting springs without removing the top control arms and that annoying pinch bolt. Car sits very well on those springs and that wheel combination!
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
  3. #42
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by Steve220 View Post
    Hi Steve, here's a pic of the top nut that was removed
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
  4. #43
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    The more i look the more it seems to be the same hight....i have even put them pics together on photoshop.
    I will be measuring mine before and after in the workshop i think.....
    Like you say, Hopefully it will settle a little more
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
  5. #44
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Are you rims 18's or 19's.........
    Privacy Glass
  6. #45
    Dec 2010
    224
    Looks sweet mate
  7. #46
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    479
    Can be done without removing the pinch bolt but it's a bit fiddly. Raise the car and support it then jack up the wishbone to compress the spring. I couldn't get my spring compressors in to hold the spring so used several lengths of binding wire to hold the spring under tension then let the wishbone back down, just make sure the spring is securely bound down. Then it's just a case of removing the bottom and upper bolts and that lets you remove the whole lot at once without touching the pinch bolts. Sounds easy but it's still a fight tbh, I found it easier and quicker to remove the pinch bolts.
    Looks great tho Mac, big improvement. My H&Rs dropped a wee bit over the couple of weeks after fitting.
  8. #47
    V6 Quatt's Avatar
    Feb 2008
    783
    Agree
    Quote Originally Posted by Tiffy View Post
    Looks spot on mate......Getting mine on this week i hope.
    B7_Fur......everywhere i have read it says the Eibachs IMPROVE the ride comfort as the OEM set up on S-Lines is very crashy........
    Torque the Torque
  9. #48
    V6 Quatt's Avatar
    Feb 2008
    783
    Great Work mac - looks much better....yes it will settle and sit a bit lower after a few hundred miles etc.
    Quote Originally Posted by Macdoon View Post
    I thought that too, hoping they may drop a bit more
    Torque the Torque
  10. #49
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by V6 Quatt View Post
    great news, now to sort out the next mod lol
  11. #50
    V6 Quatt's Avatar
    Feb 2008
    783
    Here is a view H&R once settled with 18's on 19's going on soon
    Macdoon likes this.
    Torque the Torque
  12. #51
    Jun 2011
    245
    looks loads better mate , now get some 15mm spacers on the rear and fill those arches
    as for the pinch bolts when i fitted mine i removed the two rear bolts that attach the upper arms to the strut top and left the pinch bolts intact a bit fiddly but reduces the risk of the bolt snapping or the upright breaking as in this post .
    regards dav
  13. #52
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by davsa4 View Post
    regards dav
    Looking good MAC, can't wait to get mine lowered now!
    As for the method you mentioned Dav, aren't these said bolts quite tricky to get at and undo? I may just go about this method when fitting mine.
    Thanks, Az.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
  14. #53
    Jan 2013
    Moray
    228
    Quote Originally Posted by ajax1976 View Post
    My spring compressors are compact and will easily get in either side of the spring. I think if i do ever adjust or modify the suspension in anyway, this is how I will get the shocks out. The Audi A4 haynes manual does explain a lot of it, but personally i'd have done it all another way. Advantage of being an ex mechanic
  15. #54
    Jun 2011
    245
    Quote Originally Posted by A4_MaJiK View Post
    Thanks, Az.
    yes mate they are a bit tricky but not too difficult .
  16. #55
    Macdoon's Avatar
    Essex
    1,569
    regards dav
    Thanks mate, the offset is currently et35 so realistically how far out can I go without rubbing front and back
  17. #56
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    479
    I don't think you can go anymore than 3mm spacer if you're et35 at the mo. I tried et30 on the rear of mine with an 8.5j 19" wheel 235/35 tyres and had light scubbing over speed bumps. Now I'm et32 on the front and 38 of the rear and have no scrubbing.
    Are you sure you're definately et35? Once its settled you'll get a better idea what if any spacers it'll need.
    Just remembered I was et32 on the rear with my 18" S4s with 225 tyres and had no scrubbing.
  18. #57
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    If it helps, my rear wheels are 19" 8.5j 235/35 ET48 with 15mm spacers (ET33) and no issues here.
  19. #58
    Macdoon's Avatar
    Essex
    1,569
    Think i'll leave as is, thanks for the info
  1. Eibach Springs
    By imported_Coullio in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2005, 21:26
  2. S3 - Eibach Springs
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2004, 13:43
  3. Eibach Springs...
    By Neal_A3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2004, 21:48
  4. Eibach springs
    Last Post: 9th December 2003, 17:57
  5. Eibach Springs on A3 T Sport
    By paul_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:18
