Volks AutosAH Fabrications
Results 1 to 7 of 7
    QUATTRO
    Jun 2011
    66
    knocking noise when breaking
    Hi some advice needed please
    Just fitted new disc & pads at the front - the rear will get done end of the month, after fitting new discs and pads i took the car for a test drive the breaks are working fine but I get a knocking noise when breaking -the faster the car is moving when breaking the faster the knocking noise gets
    Does a yone know why this is happening ? The car is a A4 DTM 2.0 Quattro
    James
    27,099
    Possibly pads moving in calliper, shim would probably sort this out.
    Try reversing & see if knocks, then going forward & see if knocks, if so then its this.
    QUATTRO
    Jun 2011
    66
    Thanks ill give this ago I will remove calipers/pads and refit tomorrow
    James
    QUATTRO
    Jun 2011
    66
    Just been out for a spin - noticed the knocking when moving forward seems fine whilst reversing will have a look in the morning
    QUATTRO
    Jun 2011
    66
    Finally sorted the noise out I had a nightmare fitting the new discs and pads first the noise then a faulty brake pad sensor-I got these from GSF parts and was able to return the faulty brake pad under warranty, I paid £206 for discs and pads just for the front and been quoted £75 for the rear discs and pads - I bet I could of got these cheap elsewhe
    Looking forward to payday to refurbish my alloys (gun metal grey) cant wait
    Cheers James
    27,099
    So what was the noise then?
    QUATTRO
    Jun 2011
    66
    Sorry mate thanks for the advice
    The discs were Bosch one came with grey anticarossion paint witch had biult up under the pad slightly - not sure if I was supposed to have removed with thinners ? I have cleaned the pad and disc remove the hard flakes of paint all seems fine now cant wait to do the rear discs (NOT) ha
  1. Replies: 0
    Last Post: 13th April 2012, 09:28
  2. Clunking/knocking noise when full lock...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2012, 08:01
  3. Strange knocking noise when braking
    By leighlo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2011, 08:14
  4. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  5. A4 Strange noise when breaking
    By AudiNick in forum General Technical / How To
    Last Post: 17th April 2007, 20:28
