EM TuningVolks Autos
Results 1 to 14 of 14
    Danny-boy's Avatar
    Jan 2013
    477
    10mm Wheel Spacer Advice
    Hi all,
    I need some 10mm (per side) spacers for the rear of my B7 A4 2.0T with extended taper bolts.
    Have heard recently that some don't fit, so I need some that do.
    I'm happy to buy bolts separately if somebody can tell me the dims for 10mm extended.
    Do they need to be hubcentric if the hub sticks out half a mile. I run spigot rings so assume it would be hub-spacer-spigot-wheel.
    Any recommendations welcome. Or if you have some lying around.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    472
    Assuming you're meaning 10 per side and not 10mm per axle(5mm either side)?
    Easiest thing is to take a wheel off and measure bolts and add 10mm.
    Can't help with source of hubcentrics that fit, others say they run them but seem to be reluctant to post up details of them, either that or hub sizes vary across A4s.
    What you could try, As you're running spigots I think you could take the spigot out the wheel, slide the spigot on to the hub then draw it back as if you were removing it so as it's 10mm from the face of the hub. If it still sits tight on the hub with no play then you could get away with a plain spacer as there will still be enough of the hub protruding to safely mount and centre the wheel.
    Depending on how deep the spigot sits in wheel you might need to add the depth to the 10mm if its slightly recessed, if it sits flush with the face of the wheel you'll be good with just drawing it back the 10mm.
    I used this method before ordering my 6mm spacers for my summer wheels, I've shortened my hubs(shaved) but still had enough for a 6mm flat(plain) spacer and can still safely mount and centralise the wheel on my hub.
    Danny-boy's Avatar
    Jan 2013
    477
    Yeah, 10mm per side - original post edited.
    Thanks for the advice, might check with a 10mm MDF wooden tester.
    Oct 2009
    stoke on trent
    17
    has anyone found or tried these off ebay
    AUDI A4 BIMECC HUBCENTRIC WHEEL SPACER KIT 10MM | eBay
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    iv just used these on 2 cars
    and there spot on
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Does fitting spacers require a wheel alignment check afterwards?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    bez101's Avatar
    Jul 2008
    8,429
    no just stick em on
    Danny-boy's Avatar
    Jan 2013
    477
    Awesome, I'll get some of those if you say they defo fit.
    I'll be getting 4WA anyway as it's on my to do list.
    Cheers all
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by Danny-boy View Post
    Cheers all
    I just had mine done when the springs were fitted; hence the question. I'm not in a hurry to have another alignment check.
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by jdp1962 View Post
    Spacers will alter it slightly, but not enough to get it re-done.
    bez101's Avatar
    Jul 2008
    8,429
    iv never known spacers to alter it even a small amount
    itsonly moveing them out not like springs arms etc.
    Danny-boy's Avatar
    Jan 2013
    477
    I always was told that if you increase the face-to-face length, that it would slightly alter the camber both sides. Only a small amount.
    I may be wrong though.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Spacers will only minimally affect camber/wheel alignment. The thing it affects the most is the load on the wheel bearings.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Apr 2012
    N. Wales, LL22
    1,224
    it will adjust camber slighty, think if you had 1 foot wide spacers the cars weight would push it down more
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  1. WHEEL SPACER ADVICE NEEDED
    By harra1979 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 14th March 2013, 22:27
  2. Wheel Spacers - Advice please
    By jambofuz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2012, 10:47
  3. Wheel spacers.....advice needed.....pls
    By mjs993 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th December 2010, 13:34
  4. Wheel spacer advice
    By Dan76 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th February 2010, 10:59
