Results 1 to 7 of 7
    Mar 2013
    36
    A4 B7 2.0 TDi EGR valve exhaust inlet pipe
    Hi all,
    Been having lots of problems with cold starting, lumpy idle, then a P0401 code - exhaust recirculation low flow. It's a 2006 BRD engine.
    Read a few posts which pointed me in the direction of the EGR valve. I removed this yesterday, and sure enough it was caked up with carbon deposits. I started cleaning it, and while waiting for the ball and chain to fetch the carb' cleaner, checked the EGR valve actuator drive gears for wear as had been mentioned several times, and found the teeth on two of the gears completely worn out.
    Checked, and these wouldn't mesh to open the valve, so wouldn't, I presume allow the exhaust gases to be mixed into the fuel / air mix to dilute the combustion mix to reduce NOx production.
    Saved me a job of cleaning the EGR, and I've ordered a new one from GSF, however, there's LOADS of carbon build up in the stainless steel exhast gas inlet pipe. I'd like to remove and clean this pipe, but can't see where it goes, and how to remove it?
    Anyone have any ideas please?
    Thanks very much in advance
    Mar 2013
    36
    Scrapped the idea of taking that pipe off, and instead attached a 'bung' of sponge to a wire, and pushed it down the pipe beyond the most blocked bit. Then scraped the carbon build up from the accessible bit of pipe, and pulled the sponge pig out with all the debris.
    Now getting carried away a bit, and have removed and cleaned (as best I can) the inlet manifold. While this was off, I checked the vacuum actuator that turns the flaps on the inlet manifold, and found it doesn't hold a vacuum. Ordered a new one, took the old one to bits, and the diaphragm inside it is damaged.
    Anyone know what effect this would have??
    Mar 2011
    North Wales
    201
    Mine was the same, I was getting hesitation at about 1600 - 1800 rpm and lumpy idling. Replaced it and while the inlet manfold was off cleaned it all out with carb cleaner. Ran fine after that.
    I also took it apart and found it was split.
    Still a bit slow to start on cold days though, after initial start it's fine all day afterwards.
    Mar 2013
    36
    Cheers for that. Yeah, I can't see this being the cause of the cold start problem, but if it stops the lumpy idle etc, it's a start!
    Gonna try some injector cleaner next, as the glow plugs were changed about 8k ago, though I have read that some need the ceramic and some the metal glow plugs, and it can make a difference if the wrong ones are fitted
    Mar 2011
    North Wales
    201
    I'm pretty sure the brd engine takes ceramic glow plugs. If you were charged about £30 a glow plug then these will have been ceramic.
    Mine used to start fine before the injectors were replaced on recall.
    Mar 2013
    36
    All sorted, replaced seals between EGR and anti-judder valve, EGR and exhaust inlet, and between EGR and inlet manifold. Replaced inlet manifold gasket, reset engine codes and BINGO!!! All working, and engine light has stayed off after about 50 miles now.
    Lumpy idle has stopped, car runs much more smoothly, seems to pull from low rev's miles better too.
    Cold start still a problem, so injector cleaner here we go!!
    May 2012
    87
    try a new coolant temp sensor-it worked a treat for me
  1. EGR valve location on 3.0 v6 tdi engine
    By .Jas. in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th August 2013, 09:22
  2. Audi A3 2.0 Tdi EGR Valve
    By Adam_A3_ in forum For Sale/Wanted - Audi Cars
    Last Post: 19th March 2013, 12:11
  3. 2.5 v6 tdi EGR valve
    By Boro&Beth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th September 2012, 19:56
  4. 2.0 TDI EGR VALVE
    By X2JPH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2010, 11:08
  5. 2.5 TDI - EGR Valve
    By hodgy0_2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2009, 13:11
