Volks AutosChris Nott
    Dec 2005
    england
    10
    New clutch needed....which one?
    I've got a A4 tdi 170 that's been mapped to 219bhp with 320lbs torque the original clutch has just started to slip in high gears under load. I'm unsure whether to replace with another standard clutch or go down the uprated route? I've seen black diamond do a stage 2 clutch for £200 but unsure if they are any good?
    Any advice appreciated.
    Keets
    Jan 2013
    Moray
    228
    Out of morbid curiosity, what have you had done apart from the map to get that power from the 170?
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Those outputs are close to 3.0TDi territory. Would it be worth enquiring whether a 3.0TDi-spec clutch would fit your car?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Dec 2005
    england
    10
    Dpf filter out and stage 2 map @ statller in sheffield
    Dec 2005
    england
    10
    Jan 2013
    Moray
    228
    Oh, I thought it was power at the wheels. My bad.
  1. New clutch needed
    By RyanJonS4 in forum Awesome GTI
    Last Post: 22nd May 2009, 10:33
  2. Clutch Kit - Which one? - How much? - Where?
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2008, 17:44
  3. new clutch needed
    By s3ilver in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2006, 13:27
  4. Upgrading to a new b6...but which one?!
    By imported_Audi_DavE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2006, 23:50
  5. new clutch needed after remap??
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2004, 17:24
