Volks AutosSky Insurance
Results 1 to 8 of 8
    Danny-boy's Avatar
    Jan 2013
    477
    Undertray Fitting help!!
    Hi all,
    Bought all the bits to reaffix my plastic undertrays, but I don't know where they go!!!
    Any tips would be most welcome.
    May 2011
    Suffolk
    308
    Bit of a job to explain mate really. If the original undertray has fallen off i would guess that most of the female fixings will still be fixed onto the chassis, May become more obvious when you get it up in the air
    The white washer type pieces push directly onto the large black plastic fixings, which then push through the undertray and fix by half a turn into the chassis
    I think that the smaller metal black screws incorporated with the bright female fixings may fix the tray on along the line closest to the bumper. Also there is a fixing for the tray inside both wheel arches at the very bottom , these could be for that too.
    As i say mate..... bit hard to explain. Good luck
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by tuffy View Post
    Thanks for taking the time to respond buddy, I appreciate it's hard to explain.
    The clear discs don't seem to fit over the large black fixings, so thought I would check. The amounts of each was confusing as there are 7 white discs and only 4 large fixings. That's why I thought they might have something to do with the screw / thread insert fixings as there are 7 of them.
    I'm lost with the black rubber things on the right too.
    It may well be more obvious when underneath, but fore-armed is the best way!!!!
    Dan
    READER84's Avatar
    Jan 2013
    221
    Which under-tray did you lose? Smashed mine off hitting a rabbit and not replaced it yet, need to
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by READER84 View Post
    I didn't lose either mate, had an oil change the other day and noticed most of the clips are actually tie-wraps.
    All fixing points look unbroken, so decided to reaffix as it should be.
    Nottingham
    72
    Where did you get the bits? Need the same for mine
    Volume is nothing without control
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by Simon View Post
    eBay mate, they sell them in full kits.
    Think I paid £13 all in
    Nottingham
    72
    Ace thanks
  1. will these wheels fit? help
    By new wheels in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2007, 23:25
  2. IC hose fitting (help)
    By scib4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2007, 01:04
  3. S-line rear bumper fitting help!!!!!!!!!!!!!!!!!!!!
    By Arf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2006, 10:37
  4. Side repeaters - fitting help!!
    By marcus7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2005, 17:18
  5. New Wheels, don't fit, HELP!!
    By danjones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2005, 16:06
