Badger5Monster Motorsport
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By SinghB7
Thread: Repeat and multiple glow plug failure - 3.0TDi
    Mar 2013
    Banchory, Nr Aberdeen
    17
    Evening all,
    I bought a 2007MY car with 50k miles and FASH a month ago. During the pre-sale inspection, No.2 glow plug was found to be open circuit. It was replaced with a new OEM part supplied by TPS.
    In this recent cold snap, I noticed that the car was a little reluctant to start and had VCDS hooked up to check all was well and found that No.2 glow plug is open circuit again, as is No.4 & No.5.
    Any idea why a brand new glow plug should fail again so soon - literally no more than a couple of dozen starts, and also why there appears to have been a cascade effect causing the other two to fail?
    No other fault codes appear, just those relating to the open-circuit glow plugs.
    The car has a 3 month warranty, so I'm keen to get to the bottom of it and not be left with a lemon...
    Many thanks,
    Andrew
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    639
    Re: Repeat and multiple glow plug failure - 3.0TDi
    No2 glow plug should also have warranty from TPS
    Mar 2012
    Essex
    118
    Could well be a problem with the wiring loom. Apparently they get very brittle with age.
    Mar 2013
    17
    So, car going in for six new glow plugs under warranty on Friday - hoping that will sort it. Aside from a visual inspection looking for signs of heat damage, are there any other ways of checking the loom without physically testing the continuity of each and every core?
    Mar 2013
    Southampton
    128
    Sorry to resurrect an old thread I just wondered if you ever got to the bottom of the failing glow plug problem, I have a 3.0TDI, last service said I had a failed No.1 glow plug, and just recently had the management light come on and stay on till I cleared it on VCDS, but then I had No.2 glow plug fail, which was quickly followed by No,3 failing.
    Dec 2012
    Birmingham
    295
    Visit SinghB7's Instagram Channel
    The wiring loom for the glow plugs will need changing. Happened to mine just after fitting new plugs, its quite common the looms just get old and brittle.
    Andy27168 likes this.
    Mar 2013
    Southampton
    128
    Quote Originally Posted by SinghB7 View Post
    Was yours a 3.0TDI? I have just looked at the EPC and it appears there is no separate loom for the Glow Plugs, you have to replace the entire engine loom and at a £1000+ for the loom I hope it is,nt that.
  1. ESP and flashing glow plug icon. Lateral acceleration sensor?
    By Taff D in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2012, 18:52
  2. 1.9 Tdi ESP icon permantely on dash and also glow plug
    By Black_B6 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th May 2012, 10:51
  3. Extending Glow Plug Time 2.0TDI in VAGCOM?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2010, 20:15
  4. Where are the glow plugs? (A3 2.0TDi)
    By LSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2009, 10:44
  5. ESP and Flashing Glow plug warning lights !
    By richpick in forum Diesel forum
    Last Post: 14th February 2008, 18:22
