    Sep 2007
    Chester
    46
    Turbo / Boost Leak??
    Morning,
    Just been driving my B7 2.0 Tdi 140 to work this morning, and sat cruising in 6th gear to suddenly find no boost / turbo, so dropped it down to 5th and still the same.....after a while I had boost again?! This repeated itself again before I got here, once the boost returned the second time I gave it a thrash in 3rd / 4th and all seems fine.........
    Any ideas what might have caused this intermittent fault? If it was a boost pipe, I thought I would not have any boost full stop and heard a boost pipe come off?
    Cheers,
    Chris
    Molnboman's Avatar
    I would have thought only a diagnostic check would reveal possible reasons for that.
    Good Luck
    A
    Sep 2007
    Chester
    46
    Just checked all boost pipes and everything is fine. I had the EGR mapped out a while ago, so I know its not that.
    If it was an overboost problem, the car would go into limp mode and display a CEL on the dash wouldnt it?
    wyliss's Avatar
    Aug 2004
    North West
    283
    The divertor valve is prone to leaking. The rubber gasket perishes over time. Once replaced its like a new car again. The parts only about £40.
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Dension, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser. Tyres: presently running Vredenstein Sessanta's: SUPERB!
    Sep 2007
    Chester
    46
    Its a Tdi mate, I'm pretty sure diverter valves aren't fitted to diesels. Cheers though
    Sep 2007
    Chester
    46
    Well I gave this a scan and this is what has come up??
    EGR valve malfunction-N18
    Potentiometer for EGR-G212 signal too large
    My EGR was mapped out last year sometime, so I believe its something to do with the N18 solenoid valve, possibly an intermittent fault on this affecting the vacuum??
  1. Boost leak/ turbo?
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2011, 18:21
  2. boost leak pressure test bad for turbo ????
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2010, 13:34
  3. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  4. turbo boost?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 14:06
  5. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
