Volks AutosEM Tuning
Results 1 to 18 of 18
Like Tree3Likes
  • 1 Post By OxfordRich
  • 2 Post By crazy88
Thread: Mobile Vag Com technician - is there such a thing and worth it before buying?
    Mar 2013
    20
    I think I'm pretty set on the 1.9tdi sline avant I've found up near Stockport , its a 55 plate with FASH and 55k on the clocks, all paperwork seems to be in order and I'm set to test drive it this weekend if the weather sorts itself out (snowing here in Nottingham at the minute)
    anyway I wondered if it would be worth while having somebody run a diagnostic on the car prior to purchase and I believe VAG com is the program everybody uses?
    are there such people out there that do this kind of service for a fee? I can't see the deal being too fussed as he seems pretty straight laced and if the cars as good as they say perhaps its worth while?
    failing that I guess I could ask if we could head to a local Audi garage but I'd assume that may take a lot of time and require a pre booked slot so a mobile tech chap would be ideal.
    any ideas?
    cheers
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    Have a look in the VCDS section,a map with where and who is there,pm them for help usually beer tokens are exchanged.
    chrisa4quat's Avatar
    Sep 2004
    897
    If there are no warning lights generally there are no major problems. If you like the car and buy it then want a diagnostic check in Nottingham bring it lion garage and ill sort it for you foc
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Jul 2007
    London
    3,211
    I have seen soo many dodgy cars it defies belief ! Broken LED's on dasho and wiring the circuit to oil pump sensor is common and could cost thousands to put right. As you thought off, i would get a mobile mechanic to give it a good once over for you, it could save you potential expenses- nobody sells a good car cheap or without problems- and i would double and triple check the mileage is genuine- they are so easy to clock !
    FOR SALE:
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    I took VCDS (what Vag Com is now called) when I bought both the DTM and my wife's car.. It showed a couple of issues on both and I negotiated as a result. Find someone in the area to come with you, or pay for a pre-purchase check from the AA or somebody who actually guarantees their findings.
    damodici likes this.
    Mar 2013
    20
    Quote Originally Posted by OxfordRich View Post
    are the AA or RAC likely to have the vcds software? I must admit I did consider getting them to do checks but didn't really think they'd check Audi fault codes and the like.
    id better give them a ring to find out
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    Quote Originally Posted by damodici View Post
    You can pay 180 I think for a vehicle check if you have concerns,they'll give you a report
    yes they do have diagnostics software
    Motor Vehicle Inspection & Car Checks | RAC | RAC
    Mar 2013
    20
    Quote Originally Posted by voorhees View Post
    Cheers mate.
    yes was looking at them the other week, i did consider it but just didnt expect them to have the software. I guess they do so its definately an option.
    Ive actually taken your advice from earlier in the thread and checked out the VCDS map and sent out 1 polite pm to a member here so fingers crossed that may be an option
    Obviously im happy to pay cash for time and efforts so we'll see if anything comes of that. Theres also a 2nd car up in Burnley (first is stockport area) im looking at as well so would rather utilise memebrs of the board if i can otherwise the RAC/AA route could get expensive having multiple checks
    fingers crossed.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    Btw when checking members for vagcom make sure their last activity is recent.
    If it was me I would have a look at the car and speak to the owner/service book then after a hpi weigh up whether you want a vehicle inspection,you can get the lesser inspection for cheaper.
    I read this before buying
    Citizens Advice - Buying a car from a private seller – what you need to know
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,802
    Re: Mobile Vag Com technician - is there such a thing and worth it before buying?
    As an option, and if you're considering the rac check at £180, why don't you pay a little extra, buy a vdcs lead and then you scan as many cars as you want yourself and you won't have to rely on forum members availability etc. If you don't end up buying an audi (or any vag car since the lead works for all vag cars) you could sell the lead and might only lose £50, which is nothing really in the grand scheme.
    And if you buy an audi you'll be glad you bought it anyway. Mine has been dead handy.
    A4_MaJiK and damodici like this.
    Oct 2012
    492
    This was my thought aswel just buy vcds and away you go mate eh
    Quote Originally Posted by crazy88:1824612
    Mar 2013
    20
    Quote Originally Posted by crazy88 View Post
    how much are the leads then and is the software freeware of is there a license to pay on that as well?
    I assume there are numrous guides somewhere on the VCDS section of the forum.
    Its a good call and something id definately do.
    Its just that between now and next week of me expectiing to do the test drive and possible purchase, sorting out my own VCDS with a Lead and actually learning it to the degree id know what i was doing with somebody elses car might be a tall ask
    i can just see it now, i test drive it, fry the ecu and end up having to buy it anyway
    crazy88's Avatar
    West Yorkshire
    4,802
    The lead is the best part of £250, possibly a little more but nothing much more. Loads of places sell them. I got mine from a website called gendan.
    Just found the link, it's 263 Inc p&p. http://www.gendan.co.uk/product_VCHU.html
    The software is downloaded for free, and the lead is basically the license for it.
    As for scanning your car, there's little trouble you could cause just doing a scan. When you plug the lead in it'll ask if you want to scan. It'll take 10 mins or so, and provide a list of faults if any were found. Just use that list to wangle the price down of the car. vcds can no doubt cause troubles, but it's usually pretty clear if what you're doing is potentially risky.
    There's plenty more experienced people on here with much more vcds knowledge. Check out YouTube, there's bound to be a video somewhere telling you want to do.
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    I'm certan NHN on this very forum will do it for less than that.. PM him!
    If you buy an Audi and you don't intend to hand it to someone else for all servicing and diagnostics (who does!) you will need this cable at some point. Drink less beer for 2 months and save up
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,334
    Contact NHN ( site sponsor on here ) If you looking for a genuine vcds cable, im almost certain that the cables he supplies are cheaper than gendan. x
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    Those on that Amazon link are NOT genuine, you'll get no assistance if you post a scan on a forum and it won't work as new versions are released. Avoid at all costs, and if you do buy one, don't talk about it on here!
    Edit to add: you can see VCDS is now on 11.11.5 and this cable is stuck on some pre-historic version. Several reviews confirm it.
    27,019
    Quote Originally Posted by Danny-boy View Post
    That looks interesting - I may buy one unless people say they are rubbish!!!
    The amazon ones I know of are all counterfeit, don't waste your money.
    Danny-boy's Avatar
    Jan 2013
    477
    Thanks for the guidance, I think I'll just get my codes read professionally in that case.
  1. May be a stupid question but is there such a thing as a Strut brace that will fit 8p?
    By SneakaFreaka83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2011, 21:34
  2. IS THERE SUCH A THING.........
    By AUDI TURBO in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2008, 19:46
  3. is there such a thing
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2008, 09:28
  4. Anyone remember the website address for the mobile VAG-COM bloke?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2006, 18:49
  5. any help or advise out there on tackling some vag-com faults..........
    By edmanning in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2005, 01:52
