Always thought the door cards looked a bit plain on my car, I have black leather interior and cards are all black except for the Ally strips. I wrapped the strips a while ago and had some left over so decided today to see if I could wrap another couple of bits. The switch gear and trigger surrounds were the obvious choices so got the door card off and stripped it down.
Trigger surround was dead easy to do, switch gear one a wee bit tricky but doable. Only bit I'm not really happy about are the tiny holes for the mirror switch indication lights so will do it again once I get more wrap but for first attempt I'm happy. I know for next time how to make it better and I'm going to try and wrap into the finger recesses under the switches. I gave up trying to wrap down inside the grab handle so used an existing slight molding line about 10mm down on the inside to trim a clean edge to and it looks good. Passenger and rear doors although smaller look a bit harder to do due how they curve into the handle but sure they'll be doable. I'll give it a couple of weeks or so before redoing the switch gear one just to see how it wears but think it'll be fine and certainly looks 100x better than it was.
