EM TuningSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 44
Like Tree13Likes
Thread: You May or May Not Know ........ Tips & tricks
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    Been surfing the web and came across a few tips and tricks some of which were new to me and some that might be common knowledge but i thought i would share please add to the list and comment if they work these are all without using VAGCOM
    Enjoy
    Key Fob
    Pressing and holding the boot unlock for 2/3 seconds will unlock the boot ( unlike a single quick press to unlock the doors)
    pressing and holding the unlock button for 2/3 sec will open all the windows and and the same to the lock button will close them all
    Window pinch
    press and hold the window up for 5 sec, press down instantly to open the window all the way and hold for 5 sec while its down and instantly close again and hold all the way to the top the pinch control is now stored
    Throttle Body Alignment
    insert ignition key and turn to before the starter motor is engaged (do not start the car ) push accelerator to the floor wait 3 sec turn the key all the way back but do not remove. release the accelerator and wait 2 Min's remove the key put it back in and start the car you should notice a better response when pressing the accelerator (do this action every few weeks)
    reversing. passenger wing mirror auto tilt ( so you don't scuff those precious rims)
    move the wing mirror switch on the drivers door to the passenger adjustment position put the car in reverse mirror tilts down and shows you the kerb .( may not work on some cars )
    Climate control
    hold the auto button on the drivers side for 4 sec and release now you can control both temps with the driver side + & - buttons
    to reset and revert back to independent control just use the passenger + & - button
    turn on and off the instrument display
    by pressing the reset button twice
    De-Bose
    on the radio press and hold the menu button till you get to the Nav/ Radio or something menu and turn it all the way to zero position and press the button again the system has been de bosed and the Bass is louder
    .Jas. likes this.
    Danny-boy's Avatar
    Jan 2013
    477
    Interesting stuff, a couple there I'm defo going to try.
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    338
    Cheers for that mate. Will try a few out wish I'd tried the auto tilt mirror the other week when I scuffed a bloody alloy!!!
    A4 Avant B7
    LED Rear Lights - Mesh Grill - SLC Splittler - Ice White Fogs - Tints - Devil Eyes - Ambient lighting - LED interior
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by B7_FUR View Post
    You scuffed an alloy?
    Naughty step!!!!
    Wonder if it works on mine, it's fairly poverty spec so I doubt it.
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    please post your results guy's and if you have any tips & tricks you want to add whack em on and share !
    the window key fob , boot unlock , and throttle calibration, & air con dual control all worked for me gonna try the rest later
    mehtaman's Avatar
    Feb 2012
    Wembley, Middlesex
    63
    I've used this to reset my window regulator / anti-pintch sensor:
    Start with the window all the way up.
    Hold the switch down until the window is all the way down
    Hold the switch up all the way until the window is fully up
    Continue to hold it up for 10 seconds.
    This should reset the pinch sensor.
    The issue I had was that if I opened the window, when I tried to close it again the pinch function would kick in and it would drop the window again... bit annoying when your driving and rain starts to fall.
    It also helps to clean the green slim build up on the window seals
    | Audi A4/B7 2007 | 2.0TDi | S-Line | RNS-E | 18" S-Line Alloys |
    | Modifications | Pure Highway 300Di DAB | BlueFin Remap |
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    338
    Quote Originally Posted by Danny-boy View Post
    Naughty step!!!!
    was not happy i can tell you!!
    mirrors don't work, boot release does, always though button was broken!!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Er...the boot opening button press is in the owner's manual.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Feb 2008
    281
    did you know that you can fit 2 mcdonalds dips into the little rectangle by the cigarette lighter by the handbrake, nuggets and dips without no spilling
    D2NY G, rizzini7, .Jas. and 2 others like this.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    Fantastic observation
    gruf likes this.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    338
    Quote Originally Posted by jdp1962 View Post
    and if I had an owners manual I'd know that ....
    A4 Avant B7
    Danny-boy's Avatar
    Jan 2013
    477
    To be fair, I only knew this via my owners manual.
    I read it cover to cover when I first got the car.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    This might be worth trying.
    Download Audi A4 Quattro User Manual Free Free Download Audi A4 Quattro User ... - SoftUpTo.com
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    A man after my own heart.
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    338
    cheers Jeff, will download that at home. First car to never have a manual come with it....
    A4 Avant B7
    Nov 2012
    82
    Is the mirror tilt only available on those cars with with memory seats? This used to be the case with my BMWs if I am not mistaken.
    Follow my progress during the renovation of a 1930s bungalow. Will be kitted with multi-room audio and video throughout.
    http://buildmybungalow.blogspot.co.uk/
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    i thought my boot release was up the spout to I'd been pressing the door unlock 3 times to open the boot once i stumbled on this there was no going back lol
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    Quote Originally Posted by gruf View Post
    undoubtedly the best tip so far lol Good work fella
    gruf likes this.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Failing that, bite the bullet and buy one. Sounds obvious, but there's so much in there we need to know.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    390
    Hahaha - i actually made this very same observation for the first time last Saturday there, so funny you should bring that one up! Perfect fit too!!
    gruf likes this.
    Jun 2011
    Manchester
    227
    What is the anti pinch control all about?
    I can confirm that holding unlock on the key fob for at least 2/3 seconds makes all the windows go down, and then back up if you hold the lock button down for the same amount of time. Very useful when we have that one week of warm weather as you can open all your windows as approaching the car to let some of the heat out. My 8 year old son loves this feature too, he even shows his mates on our street!
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    Reesy's Avatar
    King of the Mods. Apparently.
    East Sussex
    3,600
    Visit Reesy's Instagram Channel
    As mentioned above, the mirror feature is only for cars with memory seats..
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    181
    I was loitering in your forum - the TBA trick worked on my B6 1.8T 190
    At least I percieved that it did. It could be placebo.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Quote Originally Posted by NOZ View Post
    Nox
    I've been asked by a colleague to ask you if the backdrop to that picture (it's a beautiful shot, by the way) is the Clune Brae near Greenock.
    Jeff
    EDIT: Said colleague has looked again, and asked me to withdraw the question, LOL!
    Still interested to know where it is, though.
    Jan 2013
    Moray
    228
    I also found that pulling the handle on the door opens it. I was amazed. No longer will I use a brick!
    CHEZ, Mike_B and audilad9 like this.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Feb 2008
    281
    I will tell ya whats missing from this?
  28. #27
    Jan 2013
    Moray
    228
    Colour
  29. #28
    chrisa4quat's Avatar
    Sep 2004
    897
    I have just checked my Bose settings and found they have been changed already. Has anyone got the original settings so I can see the factory Bose and de Bose sound? Thanks
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
  30. #29
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    Nox
    Jeff
    Jeff its Broughty ferry castle in Dundee and thanks the photo came out well
  31. #30
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Ahah, east coast rather than west. Thanks for that. I will let my colleague know, just as soon as he and his hangover return to work here in London after watching St Mirren win the League Cup at Hampden
  32. #31
    Molnboman's Avatar
    I have found that if you open the fuel cap thingy and fill it to the brim with Shell v Power, it mysteriously empties very quickly allowing you more room to fill it up....all over again! Great eh?
  33. #32
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    Quote Originally Posted by Molnboman View Post
    yeah but what fun you had worth every penny lol
    Molnboman likes this.
  34. #33
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,594
    that little sun visor above the rear view mirror had me impressed!
  35. #34
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,906
    Quote Originally Posted by CHEZ View Post
    I found mine two weeks ago, I have owned the car for 4 1/2 years
    JSD 2.59
    Synergy-Solutions
  36. #35
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Quote Originally Posted by sidibear View Post
    At least you didn't take that long to find out what those rear side window elements were for .
  37. #36
    wyliss's Avatar
    Aug 2004
    North West
    283
    I'm sure thats a VAGCOM job.
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Dension, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser. Tyres: presently running Vredenstein Sessanta's: SUPERB!
  38. #37
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    Quote Originally Posted by wyliss View Post
    What is?
  39. #38
    wyliss's Avatar
    Aug 2004
    North West
    283
    Bose
  40. #39
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,594
    well i have wondered........................................
    care to share?
    ***********EDIT**********************
    good old ask jeeves, that would be my radio aerial! DOH! silly me!
  41. #40
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    1,906
    Chez,
    I only found out about a month ago what the elements were for.
    JSD 2.59
    Synergy-Solutions
  1. Tips and Tricks
    By monkeyboy_marcus in forum RS3 Forum
    Last Post: 29th September 2012, 12:55
  2. Closed 7th May - 15th May
    By DPM in forum DPM Performance
    Last Post: 7th May 2011, 11:53
  3. I may or may not have a problem.
    By Westy_A3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2011, 10:45
  4. A3 Tips and Tricks
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2007, 09:15
  5. In case you guys and gals dont know...
    By S3K in forum General Chat
    Last Post: 19th November 2003, 19:51
