Been surfing the web and came across a few tips and tricks some of which were new to me and some that might be common knowledge but i thought i would share please add to the list and comment if they work these are all without using VAGCOM
Enjoy
Key Fob
Pressing and holding the boot unlock for 2/3 seconds will unlock the boot ( unlike a single quick press to unlock the doors)
pressing and holding the unlock button for 2/3 sec will open all the windows and and the same to the lock button will close them all
Window pinch
press and hold the window up for 5 sec, press down instantly to open the window all the way and hold for 5 sec while its down and instantly close again and hold all the way to the top the pinch control is now stored
Throttle Body Alignment
insert ignition key and turn to before the starter motor is engaged (do not start the car ) push accelerator to the floor wait 3 sec turn the key all the way back but do not remove. release the accelerator and wait 2 Min's remove the key put it back in and start the car you should notice a better response when pressing the accelerator (do this action every few weeks)
reversing. passenger wing mirror auto tilt ( so you don't scuff those precious rims)
move the wing mirror switch on the drivers door to the passenger adjustment position put the car in reverse mirror tilts down and shows you the kerb .( may not work on some cars )
Climate control
hold the auto button on the drivers side for 4 sec and release now you can control both temps with the driver side + & - buttons
to reset and revert back to independent control just use the passenger + & - button
turn on and off the instrument display
by pressing the reset button twice
De-Bose
on the radio press and hold the menu button till you get to the Nav/ Radio or something menu and turn it all the way to zero position and press the button again the system has been de bosed and the Bass is louder
Enjoy
Key Fob
Window pinch
Climate control
De-Bose
