JMB RetrofitsChris Nott
Results 1 to 18 of 18
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    Coleraine, Coleraine, United Kingdom, United Kingdom
    515
    What's that rumble sound?!?? :/
    Heard a rumble sound when driving off and slowing down or going slow ie about 10-15 mph in the photo, a) is this the rubber bushing and b) should this have movement or should it stay solid and not move.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Re: What's that rumble sound?!?? :/
    Looks like a bottom arm bush.
    It shouldn't have any play in it but it will move if forced as it's rubber, don't change just one do both sides if it is worn
    You can upgrade to polyurethane.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    would this make the rumbling sound or am I lookin in the wrong direction altogether?
    Jul 2007
    London
    3,252
    That won't rumble mate, is your's a quattro ?
    FOR SALE:
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    Nope just b7 a4 avant 2.0l Tdi se.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    That's bottom bush would make a knocking sound and the steering would feel a bit disconnected if it was badly warn.
    So is this noise still there if you put the car into nuteral and free wheel, this is to check is its drive train related.
    Are your tires Ok, my previous car an S2000 used to make and awful sound where there tires were worn/going off.
    Jack the up and put your foot against the bottom of the wheel and pull the top of the wheel towards you see if there is any play.
    F
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,088
    Quote Originally Posted by RMH1A4cab View Post
    That was my thought too. Our VW Jetta does this when the rear tyres are worn. Had it on previous cars too.
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    No it's not the tyres for definite!! I sounds more like a metal rattle, like something is loose or worn.
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    no ideas guys?
    Avnt's Avatar
    Mar 2013
    228
    Wheel bearing
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    Umm not too sure. is sounds like metal rumbling together like something is loose. I replace a wheel bearing on the drivers side last month. could it be anything else?
    Molnboman's Avatar
    Does the rumble / noise go away when you turn the steering wheel?
    A
    Avnt's Avatar
    Mar 2013
    228
    Brakepad fouling on the disc. That gave me a rumbling sound
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    The rumble only happens when im coasting/slowing down, coming to a stop or taking off slowly. like a jingle rattle as if something needs tightened. :/
    Molnboman's Avatar
    Disnae sound like a bearing from my experience then. Could be something between your pads and disc ( gravel, gunk etc ) I have always been very reluctant to do this, however, I was recommended by my garage to give the brake/ discs a good, careful "blootering" with a pressure washer ever now and again on my Avant.
    Good Luck and keep us posted
    A
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    I always thought that a wheel bearing gave off a humming sound? Although I'm not very technical when it comes to cars mind you. the brakes do feel like they could be doing with a new set. ( a bit of travel when braking ). and the disc do look a bit worse for wear. If i jack the car up and push/pull the wheel to see if there is any play/movement, will this determine if its the wheel bearing?
    Avnt's Avatar
    Mar 2013
    228
    Ye youd feel movement. If ur due some brakes its a good chance that is it. It did on my volvo at the rear but it sit it all the time. Changed disc and pads nice and quiet now apart from the drop links knocking their tits off lol
    Jan 2013
    Moray
    228
    Wheel bearings can make a droning sound or a rumbling sound depending on how far they are gone. If it makes it more when steering one direction then it will be side dependant. Brakes will only make a rumbling sound if you have no pads left.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
  1. What is that knocking sound??!!!!
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2011, 21:36
  2. Creaking sound from base of steering column - what's that then?!
    By calvin in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2010, 23:47
  3. whats that buzzing sound when you start up a 2.0 tdi.
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2008, 14:59
  4. whats that 'pinging' sound on start up?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th July 2007, 21:56
  5. What was that noise!! WOT acceleration 2nd to 3rd Bang!!!
    By IanL-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2005, 10:12
