Chris NottEM Tuning
Results 1 to 17 of 17
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Indicators with a mind of their own!
    Over the last few days, whilst driving the car, both the indicators begin to flash as though my hazards are on. The hazard triangle doesn't illuminate, just the signalling arrows on the dash light up together for 4 flashes and then go off! Doesn't seem to be any sort of pattern or a trigger which makes them do this, just becoming more frequent.
    Any thoughts?
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE VW Touareg wheels with 25mm spacer/adapters all round, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
    26,777
    Scan the car 1st, I do wonder if the convenience module has an issue.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Hi guys, just a quick update, eventually got round to scanning the car.....and showed up no faults! Indicator relay perhaps??
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Had the same problem on my old Mk4 Golf, replaced the relay (hazard light switch) in the end. Cost me about £9-10 from my local TPS about 2 years ago.
    Az.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Cheers Az, now off to find a part number!
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Right guys, have removed the hazard light switch and was on the way to Audi to get replacement, as the indicators went off!! As the hazard light switch was completely removed, surely it cant be at fault. My question is, does anyone know which one if the 'flasher' relay in the fuse box, as I am now thinking that is the culprit!
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    133
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Quote Originally Posted by Abb View Post
    Sorry for the late response, not been on in a while. The hazard light switch IS the relay for the indicators! Hence why they don't work with the switch disconnected.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Quote Originally Posted by A4_MaJiK View Post
    Thats the point! They did go off... As in they continued to flash as they did prior to me removing the hazard light switch.So to clarify, they flash regardless if switch is connected or not.
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    247
    Maybe way off here but is the passenger floor well wet, the convenience module is under the carpet if it gets wet then it can fail, have had this before, the culprit was blocked drains in the battery well under the bonnet, water was leaking into car and caused the module to fail this was on (b6) model but maybe worth a look
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Right I'm lost with this one I'm afraid lol
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    The saga continues .... Had it looked at by an auto electrician, can't seem to find anything wrong, indicators still randomly activating! Taking on board what Chris-Vspec and NHN has mentioned re the convenience module and this is going to be my next port of call. Questions ....is the module just located under the front passenger footwell carpet? Is it easy to get to and remove? Can it be tested to see if its at fault or should I just replace and hope it is? Finally, what does it actually do? Must stress, the car is absolutely spot on without this annoying fault!
    Thanks for all your help guys!
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    654
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Quote Originally Posted by rizzini7 View Post
    cheers for the link, could you elaborate please. Can't seem to find any modules on there.
    Mar 2013
    Verwood, Dorset
    247
    Have you had a poke around in the passenger footwell to see if the carpet is wet? The door seal plastic strip should pop off and give you enough room to stick your hand under the carpet enabling you to see if the foam below is wet/damp, in terms of removing the module I'm not sure on the process as we paid a garage to do it.
    ours had gone pretty badly, again I must stress this was on a B6 so am unsure if the B7 suffered the same drain hole issues, not only did our lights flash on their own but the windows also went up and down by themselves. When the module was removed and dried out along with the carpets, it went back together and everything was fine we may have been lucky I don't know but we didn't need to replace wiring loom or module.
    good luck I really hope you get it sorted.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Quote Originally Posted by Chris-Vspec View Post
    thanks again Chris, I will have a look at getting under the carpet tomorrow. Think it sounds like its the culprit. I noticed the carpet randomly wet a while ago but then it dried out and this fault developed afterwards, also have noticed the passenger window whilst closing it, sometimes drops open again once it reaches the fully closed position. Sounds very similar to what you experienced, fingers crossed I may get away by removing and drying it out! Thanks again.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Managed to remove the module, appears to be ok. Does anyone know if this can be tested?? Alternatively, apart from the main stealers where could I get one from, part number is 8H0959433k.
    Thanks guys
  1. Fuel gauge indicator with a mind of its own
    By tquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2012, 08:24
  2. Indicators With a Mind of Their Own!
    By Wai-Fan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2010, 16:34
  3. Hazard lights with a mind of their own and ESP issues
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:29
  4. 1999 A6 tdi central locking with a mind of its own.....HELP!!
    By alibob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th December 2009, 20:21
  5. Concert with a mind of its own!!!
    By alibob in forum In-Car Entertainment
    Last Post: 27th February 2007, 14:00
