Results 1 to 21 of 21
Thread: oil light
    Sep 2012
    ireland
    7
    oil light
    hi all
    my oil light is coming on in my computer on my a4 their is plenty of oil in it just woundering dose any know what might be the problem or can help me out
    cheers dec
    Jun 2011
    Great Melton Norfolk
    1,348
    Are there 3 beeps when you turn ignition on? Could be oil pickup in Sump sludged up
    chrisa4quat's Avatar
    Sep 2004
    897
    oil light
    Red or yellow?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Mar 2012
    188
    oil light
    If it's a 1.8t you need to have a read about sludge and how it affects the pick up pipe in the sump.
    Isaa's Avatar
    Aug 2012
    South London
    107
    Hi mate I've just done a post on this same problem but now I need a whole new engine because the oil pump stopped working thus the engine receiving insufficient oil. I would advise you to sort it out ASAP.
    Sep 2012
    ireland
    7
    nope just beeps once and stays on and then the jug stays on
    Sep 2012
    ireland
    7
    Quote Originally Posted by chrisa4quat View Post
    Red or yellow?
    its just the yellow jug
    Sep 2012
    ireland
    7
    Quote Originally Posted by gen.heinz guderian View Post
    Sep 2012
    ireland
    7
    Quote Originally Posted by duffy78 View Post
    its the 2Ltdi
    Sep 2012
    ireland
    7
    Quote Originally Posted by Isaa View Post
    cheers will get it sorted straight away some lads saying it could be the oil pressure sensor
    Sep 2004
    897
    oil light
    Oil pressure is red so won't be pressure sensor I wouldn't have thought. Could be bonnet catch or oil level sensor or just has used a bit of oil as daft as it sounds
    North East
    607
    Quote Originally Posted by dec1579 View Post
    its the 2Ltdi
    Could be the Oil Pump/Balance shaft issue as its the 2.0 tdi ?
    Jun 2012
    Cotswolds
    14
    its the 2Ltdi
    dec1579, can you please give us a bit more information on the engine type and how many miles you have on the clock. The engine type is on a sticker on the engine and also in the spare wheel well in the boot. It will be something like BLB, BPW etc.
    The 2.0L Tdi has a history of oil pump failure and it would be useful to know how many miles your car has covered before this fault occurred.
    There is a company called Powermax in Ireland that sell a fix to this problem if its the balance shaft drive to the oil pump that has failed on your car.
    Nigel
    Sep 2004
    897
    oil light
    Won't be balance shaft/oil pump. It's yellow warning light which is oil level
    May 2011
    195
    It will be the sensor on the bottom of the sump most likely. Had the same issue with mine a few months back
    That's if it's the amber light
    Sep 2012
    ireland
    7
    hey lads
    i rang a mate of mine today who works with audi and he said to disconnect the battery so did that left it off for while and it seems to have cleared the problem lets hope it stays away thanks foe the help will put up pictures of the car later
    dec
    North East
    607
    hey lads
    dec
    Useful tip , thanks for the posting .
    Sep 2004
    897
    oil light
    See how you go. Hope it sorts it. Did you try leaving bonnet open for approximately 30 seconds?
    North East
    607
    Why would leaving the bonnet open for the said 30 seconds work ?
    Sep 2004
    897
    oil light
    Cos the bonnet switch is the reset button basically. To reset oil light after filling car has to have realised bonnet has been opened.
    North East
    607
    Thanks for the advice .
  1. Trouble Resetting Oil light
    By Beerzo in forum General Chat
    Last Post: 20th June 2006, 21:02
  2. Audi 100 Oil Light at 3000rpm
    By blued in forum Classic Audi Forum
    Last Post: 27th March 2006, 14:08
  3. Oil light
    By imported_billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2005, 13:34
  4. Oil light
    By Ilogik in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th March 2005, 15:16
  5. Audi A4 Oil Light - HELP HELP :(
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2005, 18:02
