Chris NottEM Tuning
    Nov 2012
    6
    Rear Suspension issue SE - Different ride heights
    Got an issue with the rear suspension on my SE,
    The car is currently lowered 40mm front and 30mm back, but there is a problem with one the the rear wheels,
    Three of the wheels have a 20mm gap between the top of the wheel and the arch, except on the rear wheel which is opposite the filler cap, it has a 30mm gap.
    It's quite a noticeable difference
    Is there anything I can get a mechanic to do that will lower that one rear wheel to the same as the rest?
    Don't want to use coil-overs
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Are you checking them on level ground? Turn the car around by 180' to see if it is the same outcome. Shouldn't really be noticeable difference unless something has been fitted wrong or a component has failed. Get your bushes and shocks checked out. You getting any unusual noises?
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Nov 2012
    6
    Haven't checked from ground level, just between the top of the wheel and the arch.
    I've checked multiple times, so it's not about the ground.
    No unusual noises
    Thanks for the suggestion, it's going to the mechanic this week so I'll get if to give it a check over
    madstaff's Avatar
    Apr 2012
    73
    Always check from the wheel centre to the arch.
    That way slightly differing tyre profiles, tyre pressures, etc, dont affect the measurement.
    Audi A4 Avant 2.0TDi S-Line Special Edition
  1. Rear ride height higher than front?..
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2009, 11:47
  2. A4 Avant rear ride height too low
    By tom fenton in forum Handling
    Last Post: 6th December 2007, 20:32
  3. ride height/suspension A4 TDI
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th November 2007, 20:47
  4. standard Vs sport suspension ride height?
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th February 2006, 09:00
  5. Different Suspension Issues
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2004, 15:45
