EM TuningMonster Motorsport
Results 1 to 13 of 13
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    Wat Brakes 4 tdi a4?
    Cud u tell me the size of discs I need front & rear for A4 2.0 tdi 170 avant?
    Jan 2013
    Moray
    228
    You're best measuring them as i've noticed when doing my brakes, there are 3 sizes. And please don't write in text speak, its highly annoying (from one Scot to another )
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Macdoon's Avatar
    Essex
    1,569
    Definately best to measure them fella, I asked Audi they said front were 288, measured them they were 312mm
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Steve220 View Post
    Plus one. This forum's first language is English, not drivel.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    y wots up wit drivle
    and as above measure them
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by KalEl View Post
    It might be worth going onto the website of a brake disc supplier and entering your car's details. Try this one.
    Jan 2013
    Moray
    228
    I've tried that and they still got it wrong. I'm upgrading to 3.0TDi brakes soon, as frankly the quattro's are terrible. Someone on here said I couldn't fit S4 brakes, which is really annoying as i can get them nearly new for sod all
    bez101's Avatar
    Jul 2008
    8,491
    you can fit S4 breaks
    as long as you have all the parts
    Jan 2013
    Moray
    228
    So if I can get the callipers on carriers, i'm ok? Does that mean I can fit RS4 brakes too?
    bez101's Avatar
    Jul 2008
    8,491
    yes you can
    theres a thread on her at the min
    that lists all parts needed.
    Jan 2013
    Moray
    228
    Awesome RS4 brakes would be epic, although maybe over kill for my derv bus.
    madstaff's Avatar
    Apr 2012
    74
    If you look on the chassis/build sticker you can determine the size of discs from that - 1LZ (288x22mm), 1LB/1LE (288x25mm), 1LT/1LF (312x25mm), or 1LA (320x30mm).
    But to be absolutely sure your best off measuring.
    Oh, regarding the RS4 brakes, have you priced up the discs alone?? - i hope your sitting down.
    Audi A4 Avant 2.0TDi S-Line Special Edition
    Jan 2013
    Moray
    228
    I had a 650bhp Evo 9GT with 356mm discs running DS3000 pads before this, trust me, cost on these things never phases me.
    Quote Originally Posted by madstaff View Post
  1. 02 A4 TDi 130 - metal plate clapping noise applying the brakes
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2005, 23:06
  2. 02 Audi A4 TDi 130 - brake wear
    Last Post: 5th October 2005, 23:04
  3. Correct size brake discs for A3 TDI
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 13:34
  4. s4 brakes onto a A4 tdi???
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 14:00
  5. V6 TDi / 2.8 V6 30V brakes
    By RichA3Turbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th March 2004, 10:25
