Chris NottEM Tuning
Results 1 to 18 of 18
    Oct 2012
    57
    Which OEM Bluetooth
    Iam looking to retrofit bluetooth module .
    I notice they have various letters on end. A, B, E , etc etc
    will any do are some to be avoided. I read somewhere some have limited functionality. What does this mean. Ie what is the functionality limited too
    26,762
    Some modules wont allow comfort features, like call lists through say the rns-e head unit, if you want full compatibility with the latest handsets aswell, then fit the newer modules.
    I can supply/fit this system if interested, the latest version aswell.
    1,884
    Avoid A, D & E and as HNH said look for the latest module.
    Link to the list of BT modules Audi Bluetooth / TEL interface - part numbers | Audi Forum
    Oct 2012
    57
    Quote Originally Posted by B5NUT View Post
    Ah so that's why the E ones seem such a bargain on eBay etc, what exactly is limited function though, I only Really want to safely receive calls. How much are newer ones with leads etc, baby due in Aug so want to save and fit before then.
    26,762
    Yes but if you have a modern handset then it may have issues connecting to an older unit.
    1,884
    (Should add if you have nav - RNS-E limited function = it just don't work). You get a message on the nav screen saying something like insert sim, if you get a compatible unit, you get access to, received, missed, and phone book.
    You also get this nice GUI with a compatible module.
    If you don't have navigation, then you don't need what I have said, however the D module is almost 9 years old and it would have very old software as NHN says.
    Oct 2012
    57
    No RSNE just dual din concert . Would love rsne but budget won't allow now with baby on way.
    1,884
    So you could go for the D version but cannot see the point, I take it you have Multi-Function Steering Wheel?
    Oct 2012
    57
    yes purchased but not fitted yet.
    It all depends on if I get much cash work.. I'm not adverse to a little diy. But it would take me half a day fit and I could spend the same time earning to pay a pro :-)
    1,884
    Do you have a compatible steering wheel control module?
    The Audi BT system is pointless unless you have either RNS-E or MFSW
    Oct 2012
    57
    Not had chance to check module yet, do you mean compatible with then blue tooth
    1,884
    no compatible with your new steering wheel, you have to have a steering wheel control module that works with the mulitfunction wheel, you also need a slipring which is compatible with MFSW.
    Oct 2012
    57
    Not had chance to check yet. Trying to find the post that had part numbered to check
    1,884
    B7 Retrofit MFSW / DIS Stalk
    Do you have cruise control fitted, if not it's unlikely the module is compatible.
    Your best option if you want BT ASAP would be to get a parrot kit.
    Oct 2012
    57
    Thanks yes do have cruise. I'm in no real hurry at mo
    1,884
    If you have cruise then you should be OK, but you will need the slipring.
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    I have OEM bluetooth and loom you can have, make me a sensible offer. If you have an iPhone 5 it won't remember the volume of the car when you stop the car and start it again; thats why I upgraded to the latest revision. I'll post up which version in a bit, get in touch if interested.
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    Yeah it's 8P0 862 335C and loom, and bluetooth antenna and mic, so everything you need (although it'll need coding to your car with VCDS for 100% compatibility.
    Like I said, if you have an iPhone (or probably other new generation phone) it's not capable of remembering what level you set the call-volume at last time you used it - it defaults to 100% each time. It annoyed me so I upgraded.
  1. Retrofit OEM Bluetooth to Concert 2 with Bose - Possible?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2010, 15:36
  2. Nokia N97 and oem bluetooth
    By Andy_gb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th September 2009, 22:15
  3. Anyone with OEM bluetooth...
    By SmoothAssault in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2009, 01:34
  4. OEM Bluetooth & Samsung Tocco
    By NHN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2008, 13:00
  5. Audi OEM Bluetooth Kits available
    By imported_craigyjp in forum In-Car Entertainment
    Last Post: 6th March 2006, 09:38
