    S4P4UL's Avatar
    Jan 2013
    Halifax, UK
    81
    Good front brakes S4
    my front pads are squeeling a low speeds and its pretty embarrassing! i can see it being annoying with the roof down so i was going to strip them down and clean them up, but instead of replacing with the old ones may aswell upgrade whilst im at it does anybody know which brakes are good as wel as not robbing the ££££
    27,038
    If the pads have bed in as such into the discs, you may find new pads do the same thing, I always found it was good to get either new both or new pads & get a pro disc skimmer to flatten the discs again, so no groove as such in the discs for new pads to wear into & screech.
    S4P4UL's Avatar
    Jan 2013
    Halifax, UK
    81
    how much will it cost to get the disks skimmed? my grandad is a engineer would this be something he could do?
    27,038
    Years back cost me £80 iirc, a professional skimmer that has the tools that fit directly onto the hub so they skim flat, dont attempt this with a grinder no matter how experienced an engineer you/grandad are, if its of by even minimum, it will wobble/warp, I suppose a lathe could do it I guess if it would do that diameter, but has to be completely level as such.
    S4P4UL's Avatar
    Jan 2013
    Halifax, UK
    81
    yeah he has full acess to a engineering workshop, lathe etc... for the cost of 80, i my aswell just buy new disks too
  1. 312mm front brakes
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st November 2004, 20:24
  2. S4 Front Brake disks
    By imported_cononcars in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 22:32
  3. Big Front Brakes (312mm) on a 97 1.8t Sport
    By mwarrey in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2003, 18:48
  4. Front brakes and Discs
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 14:08
  5. Front brake pads
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 16:30
