Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Feb 2013
    Unhappy Symphony problems regarding speakers cut off, help ?
    Hey guys,
    Only recently my symphony has been playing up for no reason from what I can work out.
    At low volume in cd and fm mode the speakers work fine but once the volume is increased (8 - 10 value) the speakers crackle a bit and turn off for a moment and on again in this fashion.
    There is rattling sound coming from the rear subs but still not 100% what could be the cause of this problem
    Does anybody know any ideas I could try ?
    Audi a4 2005 2.0 tdi s-line b7
    2,163
    Do all the speakers cut out?
    Feb 2013
    Yes unfortunately every one cuts off and the head unit freezes for a moment
    2,163
    If it's freezes, they I would say a faulty head unit, you could try remove it and resat the connectors at the back other than that it's a replacement HU. On the up side you could replace it with an RNS-E.
    Feb 2013
    Thanks for the reply,
    I took the head unit out and was a bit weary about the connections as I know with the re-coding, but is it safe to pull them out to check and obviously put them back in ?
    Aslo after checking the amp and the sub for connections I realised that the amp would tick every time the audio would cut off, could the head unit still cause this ?
    Also is the RNS-E an upgrade unit ?
    2,163
    The worst that could happen is the radio goes into safe mode, if that happens then you just need to enter the radio code, which is a 4 digit number, it should be with the documents that you have for the car. Sometimes the AMP does pop a little, the Radio still keeps the amp running for a few minutes after you lock the car, after that it will fully shutdown the radio & AMP.
    Yes, it's Audi's navigation unit. With you having already having the double din symphony radio it's a very easy installation, and makes a nice upgrade to the car.
    Here is an example install, just ignore the bit about removing the instrument cluster the GPS antenna can be put behind the glove box. Mod #2 Retrofitting RNS-E into my 2006 Audi A4 | Bento Box
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    I got NHN from this forum to do my RNS-E install, GPS bits and code it all to my display and I've never looked back.. a great upgrade, especially if your existing radio is broken (and it sounds like it is!)
  1. HELP! Someone has cut off the wiring loom plugs for my stereo!
    By Kylodicanio in forum In-Car Entertainment
    Last Post: 4th January 2013, 21:37
  2. Replies: 5
    Last Post: 19th June 2012, 14:01
  3. Symphony stereo cutting off and on again on CD and radio
    By Congorobot in forum In-Car Entertainment
    Last Post: 5th June 2012, 21:14
  4. Fuel cut off problem...
    By hatmeow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2009, 09:17
  5. starting cut off
    By sahkel in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2003, 15:35
Tags for this Thread
